Author Topic: This is Ruby  (Read 15707 times)
This is Ruby
« on: March 21, 2021, 07:03:41 PM »
This is Ruby, formerly known as "The Project"
2021-01-08_10-24-31 by Charles Marson, on Flickr
20191209_081138 by Charles Marson, on Flickr
20191209_081356 by Charles Marson, on Flickr
20191209_081017 by Charles Marson, on Flickr
I picked her up in September of 2000, drove her illegally to my grandfathers place a month later and ripped her apart. I was going to restore her in less than a year, with no full time job, and done in time for my wedding (first marriage) the following August.
Yeah right!!!!
She is a 79 Firebird Esprit, featuring T-Tops, 301 V8, rear spoiler, 14" Rally's, tilt steering, wrapped in the Carmine red exterior and Carmine red interior. It had 105,000 kms on her and sitting and time killed the engine so my donor car Black Betty gave up her engine to put into Ruby.
Like a dumb a**, I pulled it apart, traded away the clean non rusty front body parts, mint 79 nose, S.Steel rocker panel trim pieces that came on this and other things like fender wheel well trim and various other parts I didn't think I would need.
The idea is to make it a T/A clone and I plan to use the nose from a 77/78 but might be using the nose from Black Betty to start with, to get me going faster as the others need a ton of work.
I fixed accident damage on the right side
It's hard to see but the firewall was pushed into the cowl area, the frame support was bent and crooked, the sheet metal toe board area was torn in one part and pushed in, plus a bunch of other stuff that I cut out and replaced. I heat shrunk the area around the blower motor hole and above the heater core hole to pull it away from the cowl, fixed straightened and reinstalled the cab mount bracket and painted the entire area in the Chassis saver paint.
P1040503 by Charles Marson, on Flickr
P1040748 by Charles Marson, on Flickr
Couldn't find a better picture but its all fixed up, floor on the passenger side is buttoned up and coated in Chassis saver paint!!
2020-09-07_06-06-24 by Charles Marson, on Flickr
20201003_120619 by Charles Marson, on Flickr
In the pick above, the subframe had been rebuilt, re-painted, and re-installed and now I'm working on the engine stuff
With Black Betty in the garage, I was able to fire her up and proceed with removal
2020-11-30_10-55-02 by Charles Marson, on Flickr
Click on photo for sound
20201215_202638_1 by Charles Marson, on Flickr
20201223_103456 by Charles Marson, on Flickr
20201224_171221 by Charles Marson, on Flickr
This is where I'm at now as I tear into the engine
2021-01-13_11-15-01 by Charles Marson, on Flickr
So far I'm happily surprised by the condition of the top side but I have yet to pull the oil pan!
Ruby has survived through my first marriage, and I've had her for 20 years. She is my forever car and I told my son he could have over my dead body...he replied with " Yeah, I know dad, that's the idea!!" My current wife is supportive of the project and she help to keep me focused on getting Ruby back together and on the road.
So I have been procrastinating with the heads and block so while I do that I have been sandblasting, cleaning and painting other parts.
20210318_155837 by Charles Marson, on Flickr
20210318_155900 by Charles Marson, on Flickr
20210316_211240 by Charles Marson, on Flickr
20210316_211254 by Charles Marson, on Flickr
« Last Edit: March 21, 2021, 07:24:14 PM by Nexus »
Re: This is Ruby
« Reply #1 on: March 21, 2021, 10:42:10 PM »
Looking forward to seeing more progress reports! I’m sure that will be a real good car when it is done!
2000 TransAm WS6
1968 Lemans Converible
Re: This is Ruby
« Reply #2 on: March 29, 2021, 08:46:39 AM »
One thing that is rare for salt riddled winter streets is a good foundation to start with. That is the reason I picked this up instead of a trans am. The body on this car is solid with very little rust.
Lately I've been working on restoring the aluminum bolt on's for the 301 and haven't had a lot of ground breaking progress but every little bit counts!!
Re: This is Ruby
« Reply #3 on: March 29, 2021, 07:15:23 PM »
Charlie,
You are making good progress.  Intake, balancer and water pump look brand new.
By the way, I am just blown away by your shop!
Re: This is Ruby
« Reply #4 on: March 30, 2021, 07:17:49 PM »
Thank you sir,
The shop is getting bigger this year with the 16' addition being put on the end of it...wall with the clock on it!!
Re: This is Ruby
Re: This is Ruby
« Reply #5 on: May 12, 2021, 08:04:30 PM »
Well, since the last post, I am still working on restoring the water pump housing as the aluminum was really pitted on both units I had and I'm thinking it's from people using non aluminum friendly coolant.
I have also cleaned up all the casting flash and wire brushed all the surfaces on the block, and soon I'll notch the top of the cylinders to aid in exhaust gas removal. Everything was coated in WD40 to keep the rust at bay until I can get it cleaned and painted.
2021-04-29_10-11-11 by Charles Marson, on Flickr
2021-04-29_10-11-01 by Charles Marson, on Flickr
DISCLAIMER!!
What I have decided to do with this build is not the most popular way to refresh an engine, and I'm sure others will shutter but with that said, too bad, get over it...lol
Also, I am not building this for maximum power, or racing of any kind. I won't be thrashing the engine so for now, this will suffice and will likely work well unitil I can do it up right.
This is a super budget refresh build so I saved money where I could (like machine shop work) and purchased parts that I could find at the cheapest possible price. Also I am not replacing the rings, crank bearings, lifters and anything else that was working just fine before I pulled it apart.
So with that said, I purchased new connecting rod bearings, to install which will wear prematurely because of the scratches in the crank/bearing surface but It should hold out ok until I can rebuild this properly and at that point, I will purchase some better quality parts that were recommended to me.
Due to rusty push rods, I replaced those and also picked up a new, budget friendly timing chain set. A new pickup screen for the oil pump, frost plugs, temperature sensor, exhaust manifold studs, fresh fuel tank pickup screen, indirectly related to the engine and some shiny rocker cover tabs to spread out the tension from the bolts were also purchased.
2021-05-12_08-25-16 by Charles Marson, on Flickr
Also something that excites me the most is that we decided to go ahead to to install the Atomic EFI I got for Christmas sooner than later.
2020-11-30_08-17-19 by Charles Marson, on Flickr
Didn't seem to make sense to spend money on things that weren't staying with the car so with that in mind, I purchased a 7 pin electronic distributor from an 81 301, and a fuel pump and fuel filters.
2021-05-11_04-53-25 by Charles Marson, on Flickr
2021-05-11_04-53-07 by Charles Marson, on Flickr
Re: This is Ruby
« Reply #6 on: May 13, 2021, 05:51:41 AM »
Charlie, glad to see your car here again! That EFI install will be a fantastic edition to your motor. Just keep in mind that sometimes you have to play around with the settings to get the idle and off idle tuning right. The main fueling tables will self learn and adjust based on feedback from the wideband O2 sensor. Keep in mind that you'll need to calibrate the timing and other settings yourself. Also keep the main wiring as far from wiring for the coils, radio, and plug wires as possible. These can emit radio noise that can interfere with the sensors and cause issues.
So with the 7 pin distributor, does that allow for the ECU to control timing? If so that's a very smart move.
Re: This is Ruby
« Reply #7 on: May 13, 2021, 03:38:26 PM »
Charlie,
You are making great progress, looks great!
Having just gone through an engine upgrade and installing an EFI system in my car, adding EFI can be a project all by itself.
Re: This is Ruby
« Reply #8 on: May 13, 2021, 09:25:36 PM »
I like the budget rebuild.
 Forgive me if I missed it, but have you decided on a final color combo?
BTW - Thanks for getting that Ram Jam song stuck in my head!
  "Whoa Black Betty bambalam...Whoa Black Betty bambalam.."
Re: This is Ruby
« Reply #9 on: May 18, 2021, 07:31:37 AM »
I have some more studying to do and questions to ask but I have some starting point numbers I want to try for startup. The 7 pin is so that the module can control the timing during operation. MiniTA at 301 garage has gone down this route and when I get closer to startup, I will pick his brain some more.
My intention was to hide the wiring where they used to put the computers on the 81, front center console...should I consider a different location?
I am excited to have the car run on efi and making it super budget will be ok in the beginning but I do realize that it might have some longer term issues down the line due to quality but I will deal with them at that point.
"Get it on the road and get it driving for least amount of cash spent" This is what I keep repeating to myself over and over as I can always do things properly after the fact. Should allow me to enjoy the car sooner.
Colour: 2009 Yamaha Royal star metallic red / 2016 Mazda metallic red / 1980 Yamaha 650 Special metallic red...something along those lines they are all very close to what I'm after, Mazda being the only one with a red tinted clear coat under the final clear coat......at some point
It will receive a red primer sealer coat at first so I can save money for the colour and clear coats.
Re: This is Ruby
« Reply #10 on: May 20, 2021, 02:22:31 PM »
I just got the Sniper installed and haven't done the timing control yet.  Now that I am going to BBC, I am keeping a simple distributor setup and will switch to timing control with the EFI later.  It seems like it adds another layer of complexity.  I like the EFI and think you will too.
Those aluminum water pump housings always pit and check crack.  Everyone I have had has done it.
Some say the budget timing chains are the best and less prone to stretching than the double rollers.
Getting it on the road and driving will allow you to focus on specific issues one at a time, an easier way for me at least.
Re: This is Ruby
« Reply #11 on: May 20, 2021, 04:22:22 PM »
Charlie, I like your color choice, I believe I have two Yamaha motorcycles that same color. I also have followed Mini TA at 301 garage and watched his you tube videos. His experience should save you a lot of headaches.
Re: This is Ruby
« Reply #12 on: May 24, 2021, 09:22:02 AM »
Thanks guys,
Sadly I haven't worked on Ruby for a bit as I landscape the yard, set u flower beds for the wife, and do some repairs to my Airstream but pretty soon everything else will get put on hold as I don't want to go to long not working on her.
I might have mentioned it but cylinder notching for the exhaust valves is the next job then a good cleaning before I work on the heads.
Re: This is Ruby
« Reply #13 on: May 28, 2021, 01:04:48 PM »
Yes and all those projects, while not difficult, can eat up a lot of time.  I got back from Florida and absolutely had to redo the gutter on the south side of my house.
Re: This is Ruby
« Reply #14 on: June 26, 2021, 02:12:57 PM »
I was able to get the cylinders notched for better flow out the exhaust valves, and I also started disassembling the heads
2021-06-25_04-02-46 by Charles Marson, on Flickr
the black marker is what needs to get removed at a 45 degree agle about half way down to the top of the piston stroke
2021-06-25_04-03-54 by Charles Marson, on Flickr
2021-06-25_04-05-12 by Charles Marson, on Flickr
All cleaned up!
2021-06-25_04-04-51 by Charles Marson, on Flickr
Re: This is Ruby
Re: This is Ruby
« Reply #15 on: September 05, 2021, 09:23:56 AM »
Finally did a bit of work on the heads
I did this work a little while ago
2021-06-26_04-05-35 by Charles Marson, on Flickr
Wednesday I was able to stirp it down more, remove the casting flash, clean everything up but I still need to remove 4 broken exhaust studs
2021-09-02_10-11-14 by Charles Marson, on Flickr
Re: This is Ruby
« Reply #16 on: September 05, 2021, 02:16:13 PM »
Charlie,
Good to see some forward progress. I also like your setup for keeping the rockers and studs straight along with the valves and springs.
Re: This is Ruby
« Reply #17 on: September 06, 2021, 07:08:04 PM »
Thanks, as it will certainly help with assembly!!
Re: This is Ruby
« Reply #18 on: September 29, 2021, 08:22:27 PM »
So, I recently pressure washed the block and heads with hot water, dried them with air and heat, and coated everything in WD40 to keep the rust at bay. I then reinstalled the pistons into the block, reinstalled the crank, and when I started torqueing the connecting rod bolts, my torque wrench apparently was crapped out because I broke one of the studs. Furthermore, the gamble I took on ordering standard stock connecting rod bearings didn't pay off because the crank had already been ground once. Should've taken the 10 mins to measure but like a big dope, I didn't!!
What to do?
Well, I decided to retrieve the spare 301 that I pickled, pulled the crank and pistons from it and much to my amazement, the crank looks great. Also this crank has never been ground...I measured so the connecting rod bearing I already purchased will fit this crank. I also punched out a rod stud and replaced the broken one with one of the 16 spares I now have!
We shall see how all of this pans out!!
BTW...Torque wrench went into the scrap metal bin!!
Re: This is Ruby
« Reply #19 on: September 30, 2021, 07:14:47 AM »
At least you have a motor to work on. Keep on keepin' on!
Re: This is Ruby
« Reply #20 on: September 30, 2021, 07:36:59 AM »
Charlie,
It’s great to have a spare engine to fall back on for parts. As these cars get older parts get harder to find and more expensive to buy.
My oldest ft lb torque wrench is probably 45 years old. It has been decades since I have done engine assembly on a car engine. Now it’s used mostly for lug nut torque, I do wonder about its accuracy.
Re: This is Ruby
« Reply #21 on: September 30, 2021, 07:41:25 AM »
My dad always had is torque wrench recalibrated bi-annually to maintain accuracy but I didn't with this one because I really only used half a dozen times over the last several years. It is also a cheaper quality tool which likely has something to do with its issues. I at least have 3 or 4 other options at my disposal!!
Benefits of having a father who was an aircraft engineer/auto mechanic who is now retired!!
Re: This is Ruby
« Reply #22 on: April 17, 2022, 07:12:46 AM »
So this finally happened!!
2022-03-22_02-05-29 by Charles Marson, on Flickr
2022-03-22_02-05-39 by Charles Marson, on Flickr
2022-03-22_02-05-59 by Charles Marson, on Flickr
Third times the charm!!
First two sets of crank bearings did not fit when ordered them from Summit. Once was my own fault, second was theirs. MiniTA at 301 garage pointed me in the right direction!!
Re: This is Ruby
« Reply #23 on: April 17, 2022, 09:16:12 AM »
Looks great Charlie! I have been following your progress on 301 Garage.
I saw a comment about not much activity there. They do have lots of good information. I tried to join them a couple years ago but never got any reply, I should probably try again.
Re: This is Ruby
« Reply #24 on: April 18, 2022, 11:01:05 AM »
Progress!! Can't wait to hear this roar to life.
Re: This is Ruby
Re: This is Ruby
« Reply #25 on: April 18, 2022, 12:11:12 PM »
Coming right along!
Re: This is Ruby
« Reply #26 on: April 19, 2022, 01:43:29 PM »
Yay!!!  I love it when a plan comes together!
1977 Y82 W72 Auto
2016 Explorer Limited
2012 Mustang
Re: This is Ruby
« Reply #27 on: April 21, 2022, 06:52:24 PM »
Thanks guys,
I heard of a few people having issues getting set up on 301 garage but your right, there is a ton of great information over there and access to guys that know the 301 very well and what they can be pushed to do.
Progress is slow, but it is still progress. Next up will be to install the heads and try to find all the intake manifold bolts. After the engine is mostly together, I will tackle the transmission!!
Re: This is Ruby
« Reply #28 on: January 15, 2025, 01:20:48 PM »
Hello all,
Things are slow in the progress report and there are pictures worth posting other than the few parts I cleaned up with my home brew evapo rust. I wrote a posting about a few months back.
What has been done to date:
> A few parts were cleaned up with H.Brew E.Rust
20241009_133827 by Charles Marson, on Flickr
> Engine (301) was put back together, painted Pontiac blue, and is currently awaiting some accessories.
> Organized parts waiting to be installed, and stored the parts not getting used soon.
> Purchased a new flex plate as I noticed several cracks around the mounting bolt holes after I painted it black.
> I welded a part of the floor on the driver's side, but I still have to grind the terrible welds (lack of practice) smooth and finish welding in the other patch panels.
> I am working towards blowing up the transmission and rebuilding it but I am still in the preparation stages as I collect information and resources to guide me.
> After the transmission, I'm going to tackle the rear-end replacement, but unfortunately, I can not for the life of me remember the gearing.    I wanna say 308:1
> While at home, I'm going to continue the refinishing of the steering wheel I plan to use.
> Also while at home, I started my LED signal light conversion and when I'm done, I'll post about it but my prototype turned out exactly how I wanted it to look. Things got cold in the garage so I haven't done much about it for a little while.
Heres my prototype teaser pic:
2025-01-15_02-09-11 by Charles Marson, on Flickr
I will try to remember to take pics of things but Ruby doesn't look any different since I installed the front subframe 10,0000 years ago. Just dustier
Cheers
Re: This is Ruby
« Reply #29 on: January 15, 2025, 04:07:48 PM »
At least you are moving forward. Good to hear from you.
Re: This is Ruby
« Reply #30 on: January 16, 2025, 06:31:17 AM »
Glad to hear you are still making forward progress. We'd love to see some more pictures if you get a chance.
Re: This is Ruby
« Reply #31 on: January 16, 2025, 06:20:20 PM »
Charlie, I know you have been busy with life. Glad to see you are still finding time to work on Ruby!
Re: This is Ruby
« Reply #32 on: January 31, 2025, 07:25:10 AM »
Updated photos to come hopefully by the end of next week. No major changes to report.
I have the valve covers cleaned up, painted and ready to go back on as well as the stock exhaust manifolds. I had to break off each stud, drill it out and re-tapp the holes to accept new studs. The manifolds were also coated in a thick layer of dupli-color high heat cast silver paint. Let's see how long that will last.
I also took apart the Bosch starter, cleaned it up and have it repainted and reassembled ready for installation.
Next on my list of things to tinker with is the shaker hood base. I need to replace the sheet metal piece that is on the underside of the scoop base and get that put back together. I have some fancy copper rivets I want to use to secure it back onto the scoop.
Also, I'm gearing up to refurbish the transmission with the master rebuild kit I have for it. I don't foresee anything majorly wrong with the transmission as there are only 105,000 (65,200 miles) on the car/transmission but I am 100% confident that it has the original components from 1979. I think it's a good idea to upgrade those internals. I have always wanted to rebuild a transmission and I have more confidence knowing I have a backup transmission, just in case!! Besides, I can't afford the cost of the local shops to do it as it was going to be around $1500.00-$2000.00 with me supplying the internals....makes no sense
Re: This is Ruby
« Reply #33 on: February 03, 2025, 02:23:54 PM »
I was able to get some work done sooner than expected and I took some pics of what I've been up too.
Starter Before:
Bosch Starter - Pontiac 301 by Charles Marson, on Flickr
After:
Bosch Starter by Charles Marson, on Flickr
Manifold Before:
20240812_145020 by Charles Marson, on Flickr
After:
301 Exhaust Manifold by Charles Marson, on Flickr
Engine:
Aside from the cleaning and painting, two things were bothering me with what I did when installing the rockers. I went back and re-tourqued all the rockers, and I'm glad I did because some of them were off. The second nagging bothersome worry was about the oil pump shaft and after inspection from the top, my worry was substantiated. I forgot to install it when I installed the oil pump. So, I'll need to address that before I forget about it.
The engine is starting to look whole again.
Other updates:
I was mocking up the used Atomic EFI that I picked up a few years back and realized that the base plate doesn't match the Quadrajet setup. Thinking back I should've realized it sooner, but the efi I scored $150.00 Can, came off a Ford 302 engine.
So....
I have ordered an adapter plate from Amazon and I'm going to get the wedge base machined smaller by 1/2 inch which is the thickness of the adapter. Fortunately, the EFI is the same height from the base to the air-cleaner surface as the Q-jet and since I won't need the EGR setup those chambers are not needed. This, in theory, should keep the stock heights, and geometry I want to maintain a stock loooking shaker scoop.
Re: This is Ruby
« Reply #34 on: February 03, 2025, 04:32:08 PM »
Everything is looking great!
Re: This is Ruby
« Reply #35 on: February 04, 2025, 10:29:57 AM »
Progress! Love it!
Re: This is Ruby
