Author Topic: 1981 Turbo Trans-Am Project  (Read 48138 times)
Re: 1981 Turbo Trans-Am Project
« Reply #120 on: August 18, 2023, 05:28:23 AM »
Thanks for the update Tom,
I have been meaning to shoot you a line to see how things were coming along. Glad to see youre nearing the finish line. I hope the other drivers insurance has been treating you kindly. I also would not be surprised if the headliner was tweaked in the accident.
« Reply #121 on: August 18, 2023, 05:45:49 AM »
Wow, that lower quarter section was pretty bad! Glad that you were able to get at it now, before it became a problem in the next few years. You probably don't think so, but you are getting very close now Tom. The great thing is you can still drive the car without the headliner  :cool:. Heck, I drove my Camaro after it was painted with some seats bolted in and the dash board haha. Didn't even have the door glass installed!
« Reply #122 on: August 18, 2023, 06:22:13 AM »
Looking great and will be a comfort knowing these issues were addressed while it was already tore apart
« Reply #123 on: August 18, 2023, 07:42:36 AM »
Looks like you have made great progress. Since you don’t want to paint again it’s fortunate you found the rust and took care of the lower front fender now.
« Reply #124 on: August 31, 2023, 09:55:31 PM »
Thx guys.
It WAS really nice to feel like progress is being made. Now that this ordeal is almost over I AM glad we got to repair some sketchy spots and defects that had popped up over the past 3 seasons.
And Ryeguy is also right that…all of a sudden,  just like that, it’s Almost done!  But, not without what I hope is one last hiccup…
Last trip down I got the power door lock actuator and power window regulator installed with the 'correct' peel rivets.  The new door was not marked or drilled for the actuator, so we had to make a template from the original door in order to mark the holes...
Untitled by Tom Sherer, on Flickr
While installing the window motor I noticed that, although I ordered the same part number as before, the peel rivets I got this time appeared to be a little long.   One, of the rivets in particular didn't peel back entirely but my initial check indicated it was clearing the window fine.   Turns out...It wasn't.  The window in a certain position, and just the right vibration from a TN thunder storm lead to this...
No need to zoom in...That is a door full of shattered glass.
So, I spent time replacing the window and the poorly installed rivet while Chris worked through a guide coat on the body worked areas...
And Julie wet sanded the rest of the car to prep for a fresh coat of black
The hood isn't getting repainted for budgetary reasons.  But Classic Auto did work to touch up a couple of areas that required some maintenance/touch up...
We learned during the first go around that I was not good at bodywork stuff. But...with all the bodywork and sanding complete, I finally got to apply MY body shop, paint prep related skill...Cleaning!
For the first time this summer my TTA got a proper wash ahead of moving into the paint booth:
Three months in a body shop left the interior a mess too...
So, yeah...this is me cleaning and vacuuming our interior at around 9:30PM
.  We had stopped work for the day around 3:00 with the TTA ready to move into the booth.  Because it was literally 100 degrees outside Chris didn't want to open the big bay doors to the climate-controlled shop.  So, went out on the boat for a few hours, then stopped at the shop around 9:00 to move the car to the booth.  The car hadn't run in a month or so, so I convinced Chris and Julie to wait while the car ran a while and got up to temp.   Really, I just needed to buy a few minutes to clean things up inside.  It was driving me nuts.
The next day I continued cleaning every nook and cranny of the car while Chris and Julie taped it up...
We left TN last Thursday.  This past Tuesday they finally had a break in the heat/humidity where Classic Auto felt comfortable laying down the paint.  And...
BAM!
It's all the same color again!   Whoo Hoo!  Next trip to TN we'll be bringin' a trailer for the TTA's ride home!
I got this update from Classic today...
They've 'de-nibbed' the paint and made a first cut with 1500 Grit.  I'm told this is a little trick...knocking off the top layer about 48Hrs after laying down the clear coat helps the last remnants of solvent 'gas out' of the clear?  It'll sit like this for about a week.  Before a final cut with 2000 grit and polishing.
The plan is to make one last trip to TN next weekend.  Spend a few days getting things back together such that the car will be happy bouncing around on a trailer. Then, the 800 mile, slow, careful, butt-clinching tow back to Philly.
I'm guessing it'll take a week or so to install the interior, weather stip, decals...stuff like that...Then we're back on the road!
As part of this final assembly, we'll be adding something new...
The plan is to install this LED CHMSL inside, across the top of the rear window. I'm also working on a setup that'll use the four individual tail lights (with LED bulbs) as sequential turn signals. I'll let you know how I make out on a mounting solution for the CHMSL.   The sequential turn signals will come after the season is over.   I'm jonesing to get some miles under our belt this season.
Thanks again for the words of encouragement everyone.  It's crazy, but I was having a real physical and emotional response to seeing my car torn apart.  Right up until our 4th or 5th visit to the shop in TN. (We've made 6 trips so far.)  It was nice to have this little support group!
Thanks for checking in.
Take care.
-Tom
« Last Edit: August 31, 2023, 11:19:08 PM by TATurbo »
« Reply #125 on: September 01, 2023, 06:01:28 AM »
Tom, so glad youre nearing the end of this automotive nightmare. Not one that any of us want to go through. It all could have been a lot worse, you were spared serious injury, and you were able to save your beloved car. Looking back you can call it the  4 year refresh! Not that a repaint is what you wanted, but you now have a 'new' fresh car to tool around. Only this time you have the mechanicals dialed in and should be good to go. At least fall is a good time cruise with our dreaded heat and humidity on the decline.
« Reply #126 on: September 01, 2023, 06:13:38 AM »
Heck Yeah Tom!! That's a fantastic update. So crazy about how that window shattered though?!
« Reply #127 on: September 01, 2023, 02:21:57 PM »
Tom,
What a roller coaster ride you have been on this year. Your TA is looking really nice! Bet you can’t wait to get behind the wheel again.
 I am looking forward to seeing what you do with LED CHMSL.  Maybe something I would consider if it’s not very noticeable until it’s illuminated, then I would want the whole world to see it. I like these subtle little touches you have incorporated into your car.
« Reply #128 on: October 04, 2023, 09:25:55 PM »
You're right 5th T/A...A roller coaster ride is a good analogy for our '23 Summer.  Our Summer '23 coaster has had loops and everything!  And, although I love a good roller coaster ride...I'm ready to get off this one!
Another good analogy would be a game of “Rock 'em Sock 'em Robots”. This thing has been fighting us all the way!
We headed down to Nashville a couple (or 3) weeks ago.  We had two days to get the car together and closed up such that it'd be happy on a trailer for 800+ miles.  I'll spare you the gory details, but here are some highlights (and lowlights)...
All the body work and paint seems to have come up really well...
That said...For a bunch of reasons, we didn't have time to get a fully detailed cut and buff completed.  So our already significant @Home To-Do list grew longer.  We'll have to do some of the final cutting ourselves.
Step one was reinstalling the front facia.  This is the original nose which was not repainted because repairs from the first go 'round had been holding up and a replacement wasn't in the budget.
Unfortunately,  at some point, just handling the thing led to a nasty crack
This was one of my worries all summer.  And it has come up time and time again.  Just being in a shop environment and the act of spending hours and hours working on and around the car, things that were fine beforehand now require additional attention.
Step two was something that DID need attention before the collision, and would finally get addressed as part of this process…Replacing the T-Top weatherstrip.
 The stuff we installed back in 2019 never fit great, and already had developed holes at the seams.   This time around I chose an OER-branded weatherstrip (ThePartsPlace PN WS1012Z).  IMHO, these seem to be an improvement over the Metro Supersoft set that was in the car.  The locating tabs are hard plastic (not rubber).  And, the intersection where the T-Top Panel meets the strip on the body is a different design.  The joint is moved about an inch inward (toward the center of the panel).   I think this is an improved design.  But, It meant that I had to unexpectedly take the T-Top panels apart to replace the weatherstrip on the panel. just to get the top in the hole.
THEN I had to adjust all 8 T-Top adjusting points to get the T-Tops locked down on the new weatherstrip.
And, of course...This situation added another item to my @Home To-Do after we got home...Properly adjust the T-Top panels.
Next up I had to install the outer window sweeps to protect the windows while the car is bobbing and weaving on the trailer home.   Step three...Problems 3 and 4...
Out of the box the new outer window sweeps were super crappy.  Now, I can't speak to every set of window sweeps that come from this brand ("Reprops" PN C-10710-14KBR @ one of the big CLASSIC restoration parts sources).  I’d like to think that they can't all possibly be this terrible.   They were more gray than black. They were super thin, and not the least bit straight.  Additionally, they did not have all the mounting locations drilled out.
Look at these things!
For the record...Here's what that crappy one looks like next to the OER replacement (sitting loose on the door):
One more addition to the @Home To-Do list...Replace the outer window felts again.
Worst of all this where the fourth problem of the day (And the straw that broke my emotional camel's back) came up...
 While installing the outer window felt/sweep two of the screws pushed on the outer door skin causing a couple of dings and waves! Right at the top of the driver's door where I have to see it every time I get in the car.
 I don't know if you noticed it in the pic above...Here's a closer look...
I thought I was being careful. I did not crank down on the screws. And I even reused the screws that came off the last set(A couple of which were original parts).  Regardless of whether it's the replacement door or the sweep shape/tolerances that are different,  this was a stupid mistake on my part.
Coming where it did within the day, and within the project as a whole, this little mistake almost led me to a full-on meltdown.   I'm a very level-headed person, but I felt my eyes start to tear up when I saw the nasty outward ding in my fresh, newly painted door.   Then, I started laughing at myself for almost crying over such a silly mistake...Simultaneously laughing and crying!  My wife walked in and thought I might need to be committed.   But I'm all better now.  :???:
Other issues included busting my Satellite radio antenna (Which will be a PIA to reinstall), A couple of lug nuts that decided to cross-thread, and a realization that interior parts that were painted (or repainted/touched up) while we had them out of the car, do not match.  Even though we used the same color paint (Some of it literally left over from in a can we used to paint everything the first time)! A different color primer/base coat is the most likely cause for the color difference.  Oh…and a lost set of ‘68 rear marker lights (Since found in the glove box…Ugh.)
All in all, I think we added around 8 additional items to our @Home To-Do list.  But we did get the car closed up, out in the sun...
...on the trailer...
...and had a safe trip home...
We've started knocking stuff off of that @Home To-Do list.  And, the good news is the car's been cooperating more now that it's back in its own garage.
So, it looks like the coaster train is pulling back into the station...I just hope the operator hits the brakes as we approach the platform!  I want OFF!
Take care.
-Tom
« Last Edit: October 04, 2023, 10:43:58 PM by TATurbo »
« Reply #129 on: October 04, 2023, 09:48:58 PM »
Been following the progress and it looks like things are shaping up for you. Great to see the progress and looking forward to more updates!
2000 TransAm WS6
1968 Lemans Converible
« Reply #130 on: October 05, 2023, 05:30:55 AM »
Sorry about the door but man, overall it looks fanfastic!  Glad she is back home!
« Reply #131 on: October 05, 2023, 05:50:54 AM »
Glad your car is back home Tom, things will def. be looking up now that its back in its own garage. Will make working on it a lot easier!!
« Reply #132 on: October 05, 2023, 06:18:34 AM »
Congrats on getting the car home Tom! Bummer about the dent, but you should contact a local PDR guy. They can do amazing things and that dent is pretty accessible for them.
« Reply #133 on: October 05, 2023, 07:39:59 AM »
Tom, car looks beautiful, and even though it’s not quite perfect you’re 99% there. Keep in mind the paint and body work on your car is far above anything GM could produce back in the 70’s. I know you drive your car a lot and it’s hard to avoid tiny stone chips. In reality no one else is likely to notice these minor imperfections that annoy you. It’s time to go for some nice drives and enjoy your car,
Last year there was a thread on inferior quality window sweeps. At that time the general consensus was Fairchild sweeps through Summit were pretty decent.
http://www.transamcountry.com/community/index.php?topic=84471.0
« Reply #134 on: October 05, 2023, 07:54:28 AM »
5th said what I was going to post.  I replaced my sweeps in 2011; I don't remember the brand but they were pretty good.  The Fairchild brand on Summit gets good reviews:
https://www.summitracing.com/parts/fcd-kg2096a/make/pontiac/model/firebird/year/1979
I also have a set of metro T-top seals I need to put in but maybe I should switch.
That paint looks fantastic!  Sorry about the door and window.  You have done a crazy amount of work on that car and I am sure you will look back on the latest round as quite an improvement over the way it was before.
« Reply #135 on: October 05, 2023, 06:44:49 PM »
Tom, I feel you on the door ding. I worked so hard on my car and I'm super careful with it. I then dropped a wrench kn the fender the other day....  I almost lost it but then, like you reminded myself,  it's just a car and I get to drive it and we'll, $&%@ happens....
You car looks awesome man! Glad you are seeing the light at the end of the tunnel.
« Reply #136 on: October 21, 2023, 08:36:45 PM »
Hello again TAC,
 My car and I seem to have settled on a truce.  Since the car's been home it has been much more cooperative.
Nothing too interesting came up while going through the punch list.   But, I did try something new with the windows and I wanted to share where I'm at with the CHMSL third brake light.  Let me know what you think of it...
During the initial restoration, it took pretty much the whole first summer of driving to get the side windows dialed in.  I had eyeballed the manual, but that first time through the 'adjust-check-drive-readjust' method was frustrating to go through. This time around I combined an actual study of the Fisher Body Manual AND the use of the correct tools.
Specifically these things...
Those are Glass Alignment Gage Blocks.  GM PN J-23394-1 and J23394-2 (x2).  People are 3-D printing these things now, and the set I got from EBay fit very precisely.  I followed the instructions in the Door section of the Fisher Body manual,   Chapter 5, Page 59:
And got the windows pretty much dead on in one session.
The only downside is that the weatherstip has to be out of the car in order to use these tools.  But, if you plan ahead, these can save some time and frustration.  Worth the couple of bucks in my opinion.
I kept the manual out to get the T-Tops adjusted too...
One thing I -was- looking forward to knocking off the punch list was installing a new set of tail lights.  These weren't being reproduced when I started the restoration in 2015.  So, I had spent a lot of time trying to get my old tail light lenses looking acceptable.  Those came out improved, but still not great.   These new ones (PN 5937036 &5937034 from FBCentral) were not cheap @ $300.  But, they make the rear of the car look way cleaner...
(Note: In the pic above the old gas door with it's worn hinge was still in place.  A new gas door assembly is on there now...looking much more straight.)
One thing did come up with the new lights installed...
The gap between the tail lights and the bumper was much larger then I remember it being...
I can't say if it is the tail lights that are different, or if things just aligned differently after having the car apart.  Either way, this was easily corrected by installing a couple of washers between the bumper cover and the metal bumper inside there.
One last thing about the back end...I mentioned earlier that the accident last spring had me considering installing a third brake light.   Here's what I've come up with.  Let me know what you think...
Off-
On -
And from inside -
I'm still working on the final installation (I wont be using blue masking tape to hold the housing up.).  But, this set up is bearly noticeable when off, and it's going to give me a little peace of mind with all the miles I like to put on this thing.
Speaking of miles...Although it's rained every weekend for the past month, I still got a couple of decent drives in..
Callicoon, NY
Limerick, PA
Valley Forge National Park, PA
Eagle-eyed observers may have noted that there are no graphics on the sides (Sail panels and fender decals).  I haven't installed them yet because the car still needs a final cut and polish.   Classic Auto Paint did some cutting and polishing but did not entirely finish it out.   Mid-November I'll be taking it to a local shop to get the finish polish completed.
After that, it'll be wintertime.  And...Just like that, it's time to make a NEW punch list for off-season projects.  It really does never end.  But, I'm not complainin'.
Thanks for checking in guys.
Take care.
-Tom
« Reply #137 on: October 21, 2023, 08:46:20 PM »
Wow Tom! Cat looks great! I really like the third brake light. I really should do oemne too. I like how you can't even tell it's there.
You really put the miles on that thing!
« Reply #138 on: October 21, 2023, 08:53:30 PM »
Looks great, a lot happier than a few months ago. They sure get insurance jobs moving compared to matching projects.
The original 79-81 tail light repros were produced here in Australia, but as with anything, the moulds are elsewhere and quickly become available to anyone to put their brand name on. I wonder how many different lights there actually are, or the same pieces.
3rd light is a neat option, blends in nicely. Is it a purpose made assembly strip that size or a length of LEDs? I looked at a few options as well, nothing too seriously, none really matched the glass angle or sealed the light beam. I didn't do any tests to see just how much was even reflected with the glass.
« Last Edit: October 21, 2023, 08:55:45 PM by Wallington »
« Reply #139 on: October 22, 2023, 11:25:49 AM »
Tom, beautiful is an understatement! I bet your sleeping a little better now.
« Reply #140 on: October 23, 2023, 05:58:52 AM »
Great work Tom! Glad to see you out in the car again! If you ever find yourself on I81 near Harrisonburg, VA shoot me a text. I'd love to meet up and see that car in person. Also, FWIW Skyline drive is 15 mins from my house and is an amazing drive!
« Reply #141 on: November 17, 2023, 11:10:17 PM »
Thanks Ryan...I might take you up on that next time I'm driving down I-81. I've driven through there 100 times.  Maybe we can hook up for lunch next time I have the TA down that way.
It's been awesome having the car back.  I'm still working to get it fully dialed back in, but it's getting there.  It really has been nice being able to enjoy our favorite leisure pass-time again.
The third brake light has made driving the car much more comfortable for me.  I used to constantly worry that people behind wouldn't recognize my brake lights. (A lot of people driving today probably don't know cars didn't always have three brake lights!) It's given me a lot of peace of mind.   That said...
My mounting solution is a fail...
The light itself is just a universal 35"  "Red Car Third Brake Strip Light - Flexible High Mount Stop Brake Light IP67 Waterproof & 108pcs Lamp Beads" It's an LED strip essentially encased in a rubber housing.
Mounting it like I want, requires a shape like this...
The top (with the cut-outs slides in the rear headliner trim.  The vertical piece is where the LED strip mounts w/3M dble sided tape.  Then, the bottom flat piece covers out to the window (To control the Light out the back window and keep it from just lighting up the whole back seat.)
My initial attempt was to make that shape with some sheet metal.  The problem with that was that the mount needs a crown in it long ways across, to match the shape of the roof.  Once the metal is bent to the z shape, it wont bend that way (at least not without the appropriate metal working tools (and skills for that matter).
I decided to try making the shape by heating and bending some 1/8" FRP plastic sheeting I had laying around.
After a bunch of attempts to figure out how to work with the stuff...
I ended up with the setup I showed earlier...
Unfortunately, working the plastic with heat I ended up with an unstable shape that seems to have some 'bad' memory.  After a few cycles of sitting in the sun, then cooling it lost its shap across the bottom. You can see how it's no longer straight across on the part that goes back to the window...
Long story short...I'm currently working on a new solution, using three pieces fo FPR (instead of heating and bending one piece).  Then, using epoxy to stick them together.   I think I this method is gonna work.  The problem I'm having now is getting a nice finished look to the whole contraption.
This whole exercise is worth the time 'cause of the piece of mind the extra visibility is giving me.
Next week I'm taking the car to get the new paint cut and buffed out.  It hasn't felt fully 'finished' yet.  I'm hoping getting that done will do the trick and get the paint all the way back to where it was before Albert crashed into me.
I've been thinking of winter projects...
There are a couple things I need to get taken care of, both are a PIA to deal with...
- I need to  install new, new Turn signal switch (New parts SUCK these days.  The switch in the column now has lasted barely 12 months before it started acting up.)
- The passenger side dome light switch in the door isn't working.  The wire just came off..Should be simple fix, but that passenger side kick panel is permenantly installed with me trying to get it sealed up plus the AC Lines running through it.  Getting it out to gain access to plug in one stupid wire is probably going to take a few days.
- Pretty much all the interior hard plastic needs to come out for a repaint.  (Replacement parts from the collision do not match the earlier restored parts.  Oh...And the SEM '70 GTO Red' we used first time around is no longer available.  So, I have to send a sample to get a custom color mixed.   I suppose it's cool you can do that these days, but I just know it's going to take multiple tries to get the interior 'right' again.
I do have one project planned that I think will be interesting and cool...
I'm going to try to put together a 4-way sequential turn signal set up for the rear lights.
I'm not crazy about the LED panels that are available, so I'm going to work get two way 1157 bulbs in all 4 positions, then install a sequencer to sequence all 4 lights across the back for turn signals/flashers.  I may keep the incandescent 1157 bulbs or maybe install 1157 LED replacement bulbs.
Anyway.   Sorry I don't have anything more interesting to report.
I'll let you know how my 'Custom SEM ColorCoat' order works out.  And, I'll definitely share my sequential turn signal project when I get to that...Probably after Christmas.
Thanks for checking in...Take care everyone.
-Tom
« Reply #142 on: November 18, 2023, 08:00:58 AM »
Looks good Tom, I was  thinking about you on my recent mid west adventure. We spent a couple of days in Nashville and went right through Mt Juliet. I was temped to stop and look up your brother.
I know you drive the heck out of your car, we need to get together this spring for a saturday cruise someplace.
« Reply #143 on: November 19, 2023, 09:10:52 PM »
Great job on all the work you have done! It is awesome to see everything is back together again. Really hoping you have all the opportunities to drive your car. It looks really awesome!
2000 TransAm WS6
« Reply #144 on: April 12, 2024, 09:40:48 PM »
Hello TAC!
I’ve been lurking around here this winter but my laptop died, so I haven’t posted anything.  The good news for you is that my commentary should be less long winded typing on my IPad.
The biggest off season project we had was redoing around 85% of the interior.  Replacement interior  parts from the accident did not match the stuff we refinished 4 or 5 years ago.  So we pulled all the hard plastic out…
Cleaned prepped, and painted everything…
While everything was out we contacted Legendary Auto Interiors about the leather.  The seat cover leather had a painted on dye that was failing.   It was wearing funny and cracking with natural tan color showing through
Legendary stepped up and replaced all the leather under warranty.  I don’t have any really good pics, but the new leather looks more modern, less old leather couch.
I’ll get some better pics of the new stuff…but that pic reminds me…We also installed a new shifter plate ‘cause the silver chrome stuff wore off.  Here’s the new one.  I sprayed a clear coat over it to hopefully make that chrome highlight edge last more than 3 seasons
Another big project was the sequential tail lights.  A favorite of mine since my dad bought a 72 Cougar when I was like 7 years old.   To do this in the TA we had to modify the taillight housings…
 the two outer bulb positions had to be modified to fit 1157 bulb housings.
I made a template from the existing holes…
Cut that out and did some other trimming to get the 1157 housings to fit…
Then pull out the harness to rewire for the new 1157 bulbs and the 4-way sequencer chumpies…
Here’s a link to the finished product…
https://youtu.be/vq0ACOG6mKg?si=AkB5Ra2WmBqxCH_F
 I would have liked to wire for the instant on brake lights but that requires wiring up to the column signal wires and we had just put the interior back in.  May change that in the future.
Of course after redoing that rear harness the fuel gauge stopped working.  After going through the wires again I figured out the gauge somehow died…which was a whole other PIA because the custom backlight color paint
And custom face…
I had to take the gauge apart to move the face to the new gauge.
Then it was on to cleaning a summers worth of body shop dust and repaint overspray from under the hood.
Those intake tubes are new…they opened another unexpected project to rewire the IAT and MAF together so I didn’t have to drill an IAT bung into the carbon fiber tubes.
Right now I’m working on getting a set of GTO LS3 coil or fuel rail covers to fit my LS1 w/vintage air’s QuickTime compressor mount…
Some cutting and relocating the trans and oil dip sticks go the them in…
I’m working on finishing them up to remove the GTO and repaint.  Then I’m working on an idea to cover the AC compressor with a carbon fiber looking shroud.
I’ll post pics of the finished product and the new interior soon.
 Thanks for checking in…I hope everyone has been well.
Take care.
« Last Edit: April 12, 2024, 10:24:51 PM by TATurbo »
« Reply #145 on: April 13, 2024, 04:47:16 AM »
Great to hear from you Tom! Car still looking great! Giid to hear legendary stood behind their stuff!
Ya. An engine cover is on my list for my LS1 swaped car too. Those LS just look so unfinished although yours still looks way better than mine but I never detailed mine as well as it looks you did.
Looks like you may have single handedly kept SEM in business with all that red dye consumption!
« Reply #146 on: April 13, 2024, 05:44:17 AM »
Tom, you have been very busy. Hard to believe how bad the seat covers deteriorated in such a short period. The replacements look so much better. I had a friend who ordered Legendary interior panels and the color was not same as the original. He got part way through the installation before he realized the colors were off. Since he drilled a few small holes, Legendary refused to give him a refund. In the past I have heard nothing but good things about them, glad they did the right thing for you.
I also loved the Ford sequential turn signals, never would have thought of integrating them into my car. Every time I see your car I notice custom little touches like the little pocket on the left side of your console that I assume is to hold your phone. How did you do that?
« Reply #147 on: April 13, 2024, 06:12:39 AM »
Looks good Tom. You are the first person I have heard of that wore out a pair of seats! And I mean that in a good way :grin:
When I did my 77 I had a problem with my legendary door panels but it was my fault. I sent them back and they replaced with the correct part a year after I ordered them. That said a lot to me and I have never looked elswhere.
« Reply #148 on: April 13, 2024, 08:04:23 PM »
What's the story with the leather seat covers? Did Legendary offer a custom material and colour option in factory style? It looks like the original set was exactly that, recoated over an existing shade, and very glossy. The creases just made it looked aged, and original!
The replacements are far better using actual red leather. It looks like a pic of mine early on of my tan leather interior that a guy photoshopped into red for a laugh. Still hurts my eyes, just because you recognise a pic but the colours are all wrong and silly brain tries to adjust. Pity it can't reassemble panels too.
The engine covers may come up nicely if the GTO lettering is removed and then perhaps an inlay strip of some sort in that entire panel, stainless, carbon fibre, even decals along it.
« Last Edit: April 13, 2024, 08:09:35 PM by Wallington »
« Reply #149 on: April 15, 2024, 07:02:10 AM »
Looking great Tom! That carbon fiber intake tube looks killer! When you upgraded to the 85MM MAF, did you recalibrate your tune? If not, you'll likely have some issues going from the 78MM LS1 style MAF. I can't exactly remember your setup, but wanted throw it out there if that's the case. All that's needed is to update the Hz table in the MAF table so it's not a huge deal.
« Reply #150 on: April 16, 2024, 07:30:40 AM »
Looks awesome!  Noone is going to miss you coming to a stop!
« Reply #151 on: October 01, 2024, 10:30:42 PM »
Hello TAC!
Sorry it's been so long... I haven't posted for a bunch of reasons...Laptop hardware issues, software issues, a change in my leisure time habits (Without a laptop I took up playin' Call of Duty and Stray on my kid's XBox at night), and in large part 'cause I haven't had anything interesting to report.   I've been fine, my TA's been OK.  I hope everyone is well.
As the driving season winds down, I finally have something sort of interesting (and kinda important) to add to the community.  But first...Answers to the questions from my last post way back in April...
That little pocket on the side of the console is just an Amazon 'ABS Plastic Frame car storage net bag'. It's just attached with 3M tape, but I did have to modify the frame a bit to fit the contour of the console.  There's one on the wife's side + a similar little 4x3x2 storage chumpy made of rubber further back between the seat and the console on both sides.  They come in handy and I don't think the take away from the interior look at all.
Along those lines I also installed a set of USB Ports in that little panel on the back of the console, that the wife uses to charge her phone.
There was also a question about the MAF...
As far as I know, that's just a stock replacement for a 1999 F-Body LS1.  I didn't know it might be larger and have done no tuning.  I'm still running the stock style ECU.  I don't plan on upgrading or changing the engine/trans control until I get around to the Turbo install.  (Still a couple seasons out at this point). I intend to replace it with a Holley system at that point.
I did finish the 'fuel rail covers' and a couple other cosmetic improvements under the hood.  I finished cutting the LS3 covers to fit and remove the embosed GTO. Then I sent them to Classic Auto Painting in Mt. Juliet TN brother to be painted the same color as the rims. Finally, I added a set of 'Trans Am' Fender decals and relocated my fuel pressure guage into the driver side cover:
Regarding the seat covers...
Yes those are 'stock style' covers done in leather.  Legendary's website has a customization tool on their website that allowed me to specify black piping. I liked the first set OK, they had a lot more variation in color and texture, which I didn't hate.  But as you can see, they didn't age well.  I'm very happy with the new ones they replaced under warranty.  The gloss on the leather is mostly just my personal taste.  One could lessen that affect by using a different leather conditioner/cleaner product. Here's a couple more comprehensive pic of the replacements installed:
OK, now on the interesting/important update.  It has to do with a fail related to my sequential turn signal set up...
A couple weeks ago I started seeing an intermittent weird electrical gremlin.  The type where the dash lights and park lights come on when the brake is pressed, turn signals don't work, and my LED third brake light was on all the time.  From experience back in the day, I know these things can be caused by bad grounds, 'bad' or incorrect bulbs, or incorrectly installed bulbs, shorts, etc.    I spent several hours systematically working may way through every socket and connection back to front. I made use of every electrical tool I had...
Ultimately, I found the Brake/Turn signal wires melted where the intermediate chassis harness plugs into the main harness at the side of the fuse block:
That harness plugs in the vertical socket at the left side of the fuse block (The yellow wire in this pic obscures it a bit):
What I learned was that GM apparently engineered those wires to carry just enough load for 2 dual filament bulbs.  I hadn't thought of it previously, but the sequential set up (w/4 1157 bulbs each side) doubles the load placed on those wires when the brake or turn signal circuit was closed/on.
To fix the wires we were able to pull the wires from the intermediate/rear chassis wire harness connector and from connector on the side of the fuse block. Then add male/female terminals on each wire and hook the wires back together.  Eliminating the melted connector/terminal.
To prevent the overheating I installed 1157 style LED bulbs across the back of the car.   I had intended on using LED's across the back from the jump, but initially I had trouble finding LED's that had the same sort of soft light diffusion as the incandecent bulbs.  The sequencer kit indicated it supported incandecent bulbs, and they were functional, so I never followed up on finding the 'right' LED bulbs.
I ended up using these:
They are way brighter and diffuse the light very similar to the original incandecent bulbs.  Testing verified the load on the circuit is like 20% of the incandecent bulbs and the wires are no longer heating up.
I'll leave you with a few gratuitous pics from our travels this summer...No big trips, but around 5500 Miles none the less...
Carlisle PA
Devon PA
Lake Nockamixon, PA
Kutztown, PA
Asbury Park, NJ
Somewhere in Central NJ
Hatfield, PA
Take care.
-Tom
« Last Edit: October 01, 2024, 10:40:43 PM by TATurbo »
« Reply #152 on: October 02, 2024, 05:28:18 AM »
Great to hear from you Tom! Looks like all is well with you and the car! Nice to see some pictures too! I was just talking about you and your rear air shocks.  I purchased some like 2 years ago and have yet to install them. Someone else was asking about a stuff ride on the PTFB GT rear leafs.
« Reply #153 on: October 02, 2024, 05:40:50 AM »
Thanks for posting the pictures Tom and sorry for jinxing you haha.
« Reply #154 on: October 02, 2024, 07:26:45 AM »
Good to hear from you again. I have missed another year of getting together with my 79 but its getting closer. Hopefully next spring/summer. Your car looks great and looks like you are enjoying it. I have the calendar on the wall in my shop with your car, so I can see it every day I am in there. Constant reminder of what to shoot for!
« Reply #155 on: October 02, 2024, 08:49:16 AM »
Looks awesome and you got alot of miles out enjoying it!
« Reply #156 on: October 09, 2024, 11:15:13 AM »
Tom, you sure have done a nice job incorporating the custom details into your car. Someone who doesn't know Gen II Firebirds might think it was done by the factory. I just noticed the carbon fiber cover over the AC compressor. I don't know if that is new or I just never noticed it before?
5500 miles in one year, shows you really like to drive it too.
« Reply #157 on: October 12, 2024, 09:52:18 PM »
Thanks guys.  Hopefully we can get together next spring RoadKing.  It's cool that people have pics of our car hanging around.   Every once in a while I run into someone that saw it on the internet, a calendar, or has one of the Rock Auto magnets in their shop.  I'm happy our build resonates with people.
The AC Compressor cover is new...All the carbon fiber stuff under the hood is new this season.  The old polished aluminum intake tube and cone filter was looking ratty, so I installed the CF tubes and new cone style filter.  As part of that I came across this "Stainless steel Carbon Fiber" air filter cover/heat shield.
https://www.amazon.com/dp/B086Z65XWY?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
This is a metal peice with a hydro-dipped CF finish.   I made a couple of brackets to get it to mount over top of the AC Compressor.  I have another one I'm gonna try to use to cover the PS Pump too.  The PS pump cover will be a little trickier to fit so I put it off as a winter project.
