Author Topic: Brake pedal  (Read 1212 times)
sreta
Brake pedal
« on: November 03, 2023, 12:23:07 PM »
I want to convert my non ws6 brake pedal to ws6 and have a question about the pin relocation. I found these photos online (they were also on this forum if I remember correctly) and still don't know the proper way to do this. Should I drill the new hole inline with the other holes(option a), or should I follow the curve of the pedal arm(option b) ? I'm asking because the hole is at the end of the straight part.
« Last Edit: November 03, 2023, 12:30:23 PM by sreta »
sreta
Re: Brake pedal
« Reply #1 on: November 03, 2023, 12:26:57 PM »
sreta
Re: Brake pedal
« Reply #2 on: November 03, 2023, 12:29:36 PM »
Sorry for multiple posts, this old style version of forum is frustrating.
Re: Brake pedal
« Reply #3 on: November 03, 2023, 08:29:25 PM »
I would look at your brake pedal ratio. Recently I switched from drums to front disc on a 68 Lemans. Original brake were power brakes with 4 wheel drum and with new disc on the front the brake pedal was very hard to push. Honestly I thought it was low vacuum to brake booster . I made some changes and added an electric vacuum pump. The vacuum pump really changed little. I did not think to check the pedal ratio, however when I did it did not look right, the pedal had two positions for the rod from the brake booster one hole for manual brakes and one for power brakes. I used a formula and recalculated a better pedal ratio. Once I made the new hole and reinstalled the pedal the brake pedal feel was greatly improved and had an excellent feel and response.
If you check the ratio and drill a new hole for the pushrod and Clovis from the booster I would recommend the new hole centered to the width of the pedal.
Here is a simple diagram to calculate the pedal ratio, hope this helps.
2000 TransAm WS6
1968 Lemans Converible
sreta
Re: Brake pedal
« Reply #4 on: November 05, 2023, 07:50:15 AM »
Thanks a lot Jim. I didn't think about that ratio.
Re: Brake pedal
