Author Topic: New Dakota Firebird 70-81 Gauges Review w/ Photos  (Read 1758 times)
BBATCAR
  • I'd rather be cruisin'
    • https://www.flickr.com/photos/186526628@N05/with/49411603003/
« on: April 18, 2022, 11:22:02 PM »
I thought I'd post a couple photos and brief review on the Dakota Digital 70-81 Firebird Gauges. The first two photos are the finished interior and the next 2 photos are the gauges lit up during the install testing. The last photo are the wiring modules hidden under the dash. Additional photos, sorry about the quality...
There is so much to say about these gauges. With the ignition off the gauges look very close to factory. Once started the LED lighting brings the dash to life. Yes there is some modern touches but you have up tp 8 different digital readings at your fingertips, displaying two readings at a time in the small window. You can add several different modules that can be added to the display. The one I personally added was for AFR readings using an O2 sensor to monitor my carb A/F. Your modules and gauges can be controlled through your phone app or toggle switch under the dash. I also have electric cooling fans on my radiator and control my on/off temps for one or both fans. My car runs at 190* and rarely over 200* unless I'm really driving the car hard on a hot day.
The best part is all your gauges work perfectly and precise, including your clock that keeps time and easy to set through your phone app. High beams, signals and all other functions display though bright icons through your gauges. The gauges come with warning alarms such as low fuel or you can set your water temp to go off when you want (mine is 210*). If the alarm goes off it will buzz, a red light will also light up but everything remains blacked out and you cannot see any icons on your gauges until the alarm engages. The needles and gauge face colors can all be custom set. I found the warm white and grapefruit color needles match the stock gauges perfectly. Yes, They are pricey and I did opt to pay someone to install them along with additional modules but versus restoring my old gauges I am very happy with the results. The warranty is lifetime! I know this may not be good for the purist but for most applications it beats bouncing needles or failing stock gauges. I hope this was useful.... If there is something specific you would like to know or see, please let me know...
Dakota Gauges with AFR Module by Elliot S, on Flickr
Dashboard Restoration Complete by Elliot S, on Flickr
Dakota 2 by Elliot S, on Flickr
Dakota 1 by Elliot S, on Flickr
Modules by Elliot S, on Flickr
-AT START UP-
Start up by Elliot S, on Flickr
-CUSTOM DISPLAY SETTING Examples-
Custom Window2 by Elliot S, on Flickr
Custom Window by Elliot S, on Flickr
« Last Edit: April 19, 2022, 09:57:00 PM by BBATCAR »
1975 Trans Am 4 Speed Car
Upgraded to TKO 600 5 Speed
400 Pontiac build by Kauffman, Stroke 462 ci
KRE Heads, Roller Cam, Holley 870 Street Avenger
Ride Tech Stage 2 Pro Tour Suspension
Vintage AC/Heater, RTX Dakota Gauges
Wilwood Brakes, 17" Pontiac Wheels
Flickr Page
https://flic.kr/ps/3QPYFx
silver78
Re: New Dakota Firebird 70-81 Gauges Review w/ Photos
« Reply #1 on: April 19, 2022, 07:52:19 AM »
Nice upgrade! Very good choice.  Can you post a pic with dash lights on and no outside light.  A "nighttime" view if you will.
Also can you dim them like the factory dash lights?
Previous builds:
65 Galaxie sold
67 camaro RS sold
68 camaro RS sold
69 camaro sold
72 Nova SS
81 T/A 4 spd sold
86 IROC sold
88 Formula 350 sold
92 Z-28 sold
93 9C1 Caprice sold
94 Impala SS sold
« Reply #2 on: April 19, 2022, 12:42:09 PM »
Very cool!! That panel they made for the modules is really clean. Where is that mounted?
BBATCAR
« Reply #3 on: April 19, 2022, 12:48:32 PM »
Thanks, it is mounted directly under the steering column. They built a plate that has a lip like a hinge and only one screw to hold it in place, it is tucked behind the steering column factory plastic panel. The toggle switch of the gauges is on the bottom of the panel so you can just reach under the steering column to change the custom displays or to get into set up mode.
« Last Edit: April 19, 2022, 01:12:29 PM by BBATCAR »
Flickr Page
BBATCAR
« Reply #4 on: April 19, 2022, 01:19:28 PM »
I'll post a couple night photos and post them on my original post. When the headlights are turned on, the gauges will dim some automatically. I did add the optional dimmer to be able to freely dim them to my taste. I usually don't drive at night but nice to have feature and costs around $30 for the dimmer switch. The shop installed the dimmer at the bottom dash. Easy to reach but hidden away.
InkedInterior Dash 2 w dimmer_LI by Elliot S, on Flickr
« Last Edit: April 19, 2022, 01:32:23 PM by BBATCAR »
Flickr Page
« Reply #5 on: April 19, 2022, 05:15:45 PM »
Very nice, and great write-up and pics.  Mine are backordered until August 1.  I ordered them March 22nd.
1977 Y82 W72 Auto
2016 Explorer Limited
2012 Mustang
« Reply #6 on: April 19, 2022, 05:50:45 PM »
I like, very nice upgrade.
BBATCAR
« Reply #7 on: April 19, 2022, 09:08:04 PM »
Yep, ordered mine as soon as they launched and still took months... everything is like that 1-1/2 years still waiting on door panels.
Flickr Page
Updated71
  • TA Addiction
« Reply #8 on: January 06, 2023, 06:33:19 PM »
The thing I don’t like about my Speedhut gauges is that unless you’re looking straight on it at there level part of the gauge is obscured by the bezel due to the angle. These being more factory looking - hashes pulled in toward the center a bit from the edge- shouldn’t have that issue. Curious to hear any others thoughts on them if anyone else got them.
