Author Topic: window will not go up. 80 T/A passenger side  (Read 1715 times)
dinero
« on: April 06, 2022, 06:33:43 PM »
OK, so the drivers side window will not go up. the drive side works perfect. So I replaced switch and pigtail with new one. No difference. I ran wire from battery, unplugged motor and put wire to each side of prong on motor and window flies up and down perfect.  When I put connector back on, it's the same, it goes down ok but not up. If this was a ground issue, why does it work ok when I put power to it directly? I checked for broken wires, non found. Any ideas?  Thanks
Update: I put a test light to the connector to each side, no light on the test light? Is it supposed to light up when I touch either side of connector? Also how do I get to the wires that go into the door?
Desi Dinero
Saepe Expertus, Semper Fidelis, Fratres Aeterni
silver78
Re: window will not go up. 80 T/A passenger side
« Reply #1 on: April 07, 2022, 09:24:34 AM »
You confirmed the motor works by using the battery positive wired directly to it. Brown wire is down blue wire is up. Sounds like you need to trace the blue wire from the motor through the black rubber boot in the door jamb to the chrome switch in the console. Look for a cut wire.
Previous builds:
65 Galaxie sold
67 camaro RS sold
68 camaro RS sold
69 camaro sold
72 Nova SS
81 T/A 4 spd sold
86 IROC sold
88 Formula 350 sold
92 Z-28 sold
93 9C1 Caprice sold
94 Impala SS sold
dinero
« Reply #2 on: April 07, 2022, 11:26:54 AM »
thank you silver78. I will certainly do that. if there is no cut wire at boot, would i have to remove the covers there under the glove compartment to get to check the wires there? I have a new switch and pigtail connector. Will trace the blue wire. So would you say this is not a grounding issue then? Thanks
Desi Dinero
« Reply #3 on: April 07, 2022, 06:39:29 PM »
Clean the hinges, it's the best your grounding will be. If you ran live wires to each motor and it worked, but still only had ground through the car, then the ground is working through the hinges as it should be. The only wires left are live and directed by what the switch is doing.
dinero
« Reply #4 on: April 08, 2022, 12:04:41 PM »
I will certainly look into that. Now on to chasing the blue wire. Working on pulling the boot wire to one side and check. Will keep you all posted. Thank you
Desi Dinero
gstrandfarm9420
« Reply #5 on: April 08, 2022, 12:32:39 PM »
I had the same exact problem on a 99 Ford Super Duty, it turned out to be a broken wire from the DRIVERS side window switch in the door jam area, which had me scratching my head but fixed the wire and everything worked fine.
dinero
« Reply #6 on: April 08, 2022, 12:40:16 PM »
that sounds encouraging that I am in the right path. Thank you
Desi Dinero
« Reply #7 on: April 08, 2022, 08:33:16 PM »
it's going to be tortuously difficult to really follow that wire.   I think it would be easier to run a new one, and honestly, even that is going to be very difficult.   But in any case, as you've already figured out, there is a single circuit from switch to motor that makes that window go up.  Ground is through the hinges.
That system is made in four big pieces; the switch lead, the 2 door harnesses (short) and the section that hangs on the inside of the firewall.  All the joints in it are behind the kick panels.  The kick panels are almost beyond removable by mere humans.
dinero
« Reply #8 on: April 08, 2022, 09:10:35 PM »
i dread that kick panel so  much that it hurts.
So I did try something else. I put the connector back on the motor, then got the wire i put on the battery hot side..I double folded the wire to make it stiffer...and pushed it in from the backside of the connector on the blue wire and the window went up.
OK, so does this mean that the blue wire is in fact getting power? So is possible that the  blue side of the connector is bad? Mystery
Desi Dinero
silver78
« Reply #9 on: April 12, 2022, 06:07:06 AM »
Did you connect a wire from the Battery + post directly to the blue side of the connector on the motor and it ran sending window up?  it should of worked that way without using the chrome switch.  This will not confirm the Blue wire itself is good or bad. It only confirms the motor itself works and the motor has a good ground.
  If you take a wire and connect it from the chrome switch on the post where the factory blue wire is attached and connect the other end of the same wire to the motor. Using the switch should make the motor work and you confirmed the factory Blue wire is not working but the switch and motor are working.  Hope this helps.
Previous builds:
65 Galaxie sold
67 camaro RS sold
68 camaro RS sold
69 camaro sold
72 Nova SS
81 T/A 4 spd sold
86 IROC sold
88 Formula 350 sold
92 Z-28 sold
93 9C1 Caprice sold
94 Impala SS sold
dinero
« Reply #10 on: April 12, 2022, 09:02:51 PM »
this shows the original pigtail with correct wire colors. the other pigtail is the one I bought. So I can't figure out with wire color on the new pigtail goes to the wire color on the car itself. any ideas? thanks
Desi Dinero
silver78
« Reply #11 on: April 19, 2022, 07:45:40 AM »
Since my console is out I'll try to get a pic of the inside view of the chrome console switch with factory wires connected still.
Previous builds:
65 Galaxie sold
67 camaro RS sold
68 camaro RS sold
69 camaro sold
72 Nova SS
81 T/A 4 spd sold
86 IROC sold
88 Formula 350 sold
92 Z-28 sold
93 9C1 Caprice sold
94 Impala SS sold
dinero
« Reply #12 on: April 19, 2022, 10:49:04 AM »
Thank you Silver78. well appreciated
Desi Dinero
silver78
« Reply #13 on: April 20, 2022, 06:41:08 AM »
Here's the factory switch and wires.
Light tan -pass side down
blue/white stripe - pass side up
dark brown - driver side down
solid blue - driver side up
pink - pwr in
Years ago I gentle pried apart the switch itself removing the white plastic portion and cleaned the contacts inside.
Previous builds:
65 Galaxie sold
67 camaro RS sold
68 camaro RS sold
69 camaro sold
72 Nova SS
81 T/A 4 spd sold
86 IROC sold
88 Formula 350 sold
92 Z-28 sold
93 9C1 Caprice sold
94 Impala SS sold
dinero
« Reply #14 on: April 20, 2022, 10:13:49 AM »
pink - pwr in
Awesome, ging to give it a go here in a bit. Thanks
Desi Dinero
dinero
« Reply #15 on: April 20, 2022, 04:54:14 PM »
I was trying to match those colors with the new pigtail i bought. the new pigtail colors do not match the colors of the orig pigtail. see photo i posted earlier. thanks
Desi Dinero
silver78
« Reply #16 on: April 20, 2022, 06:21:01 PM »
If you have a volt meter you can check for continuity on the new connector. hold one probe on the pin side and the other probe on any end of a bare wire. once you have a match the volt meter will make a beep.
Previous builds:
65 Galaxie sold
67 camaro RS sold
68 camaro RS sold
69 camaro sold
72 Nova SS
81 T/A 4 spd sold
86 IROC sold
88 Formula 350 sold
92 Z-28 sold
93 9C1 Caprice sold
94 Impala SS sold
dinero
« Reply #17 on: April 20, 2022, 06:46:54 PM »
I got it, the blue solid wire had a break on it. Fixed it right up. All good to go. Thanks everyone
Desi Dinero
