The window rub strip is not installed yet
, I just set it into place for the pic. But I will be installing it very soon in the next couple of days I hope. I used a small light gauge steel stud screw to install the ones in my 77 with no problems. I have them by the thousands
They are pretty close to original.
I started to clean the original door handle when I saw Ames had them for $11! The catalogue says 'good' quality. One thing I like about Ames is that they will describe their parts truthfully. So I was figuring on the worse case being only good. They do look very nice and have a good feel about them. I think they are a good+ if nothing else. They also match the original in fit and finish as well.
It was still pretty cold when I was doing this work, but tolerable. With the overhead heater and the propane pot heater I had the shop to about 50deg which is fine with me. A little bit warmer would be nice but it sure beat the 20deg that was outside.
