Author Topic: Sides Of The Car  (Read 1063 times)
Sides Of The Car
« on: September 18, 2024, 04:29:44 PM »
Might be a dumb question, I can explain why I am asking later. But what is the Right and Left side of the car?
I consider sitting in the driver seat looking forward. The left (for us Americans) is the dr. side the right is the pass side.
Opposite for our Australian friends
Re: Sides Of The Car
« Reply #1 on: September 18, 2024, 06:41:15 PM »
Correct it's always when you are sat in the driver seat. That's how you order parts LH vs. RH.
« Last Edit: September 19, 2024, 03:30:21 AM by Jack »
« Reply #2 on: September 20, 2024, 06:14:24 AM »
The reason I asked is I am having problems with my brake calipers. I have a brand new caliper that is marked R and it matches my original marked L perfectly. The one marked L is not correct. I think I may have put the wrong one on the wrong side of the car because of this :shock:
« Reply #3 on: September 20, 2024, 06:39:45 AM »
Just to be more confusing, why do most paired part numbers on these start with the RH side, then the LH side in number sequence?!
72projectbird
  • Pontiac "Big Block"
« Reply #4 on: September 20, 2024, 10:46:18 AM »
Bleeder screws should be facing upwards. Quick way to tell what's going on just by looking at things.
71 Trans Am LS Swapped
"Put the evidence in the car"
79GoldnTan
« Reply #5 on: September 20, 2024, 06:07:06 PM »
Yep, what 72 said, bleeders always face up. Learned from doing. Lol
79 solar gold
461.   Factory 4 speed
PTFB SFC
PTFB 1LE
3.08 rear  for now
Lots O Fun
