Author Topic: Body bushing replacement  (Read 3805 times)
« on: September 02, 2024, 10:36:37 AM »
Not to bead a dead topic to death but gonna be doing these soon. Aside from the frequently mentioned need to spray with penetrating oil a week or so prior is there anything to expect or prepare for especially given I’ll be doing this on a fully assembled and driving car. Looks like I can get to the core support ones easy enough and the rear. How about the middle ones?
TA301
Re: Body bushing replacement
« Reply #1 on: September 02, 2024, 02:25:36 PM »
I replaced all of the body bushings with the subframe in place and the engine/transmission installed but no fenders, front bumper nor hood.
The core support you can do one bushing at a time. The transmission brace is one side at a time too. You will have to support the transmission and loosen the mount but not remove [ unless the mount bushing must be replaced] The subframe to main body bushings will be more involved with a fully assembled car.
« Last Edit: September 02, 2024, 02:27:38 PM by TA301 »
79GoldnTan
« Reply #2 on: September 02, 2024, 05:47:08 PM »
When I did mine I removed bottom bolt on fender and was able to pull out enough to remove inner fender. They are easy to get at then, also on the passenger side I replaced the blower mother and heater code, not an easy job! Heatercore that is.
79 solar gold
461.   Factory 4 speed
PTFB SFC
PTFB 1LE
3.08 rear  for now
Lots O Fun
« Reply #3 on: September 03, 2024, 10:30:43 AM »
I’ve pulled the inner fender before I was just hoping to avoid having to for this.
« Reply #4 on: September 04, 2024, 04:20:20 PM »
For those who have done it, has anyone replaced with rubber? I know the popular choice is poly or solid mounts but I’ve read conflicting information about going solid. This car is a driver and frequent at that so I’m tempted to stick with rubber to maintain the best ride quality.
« Reply #5 on: September 10, 2024, 09:32:23 AM »
I’ll end the discussion with myself just by throwing up a tip. In following along with the suggestions to use penetrating oil on the cage nuts I decided rather than hoping blindly to try another route.
I have a cheap borescope that I taped a small plastic tube to the end of which I attached to my PB blaster can so I was able to see exactly where I was spraying the oil to ensure the cage nuts got doused. Just a tip for anyone doing this in the future.
https://youtu.be/oBVD9A_mPiQ?si=YZBYXaCBSuTJS474
« Reply #6 on: September 10, 2024, 03:15:29 PM »
Thats pretty cool. Did you get to doing the change out yet? Overall theyre not really all that tough other than getting the stuck bolt out.
« Reply #7 on: September 10, 2024, 04:52:58 PM »
Not yet. I was hoping to this coming weekend but I’m not sure I’ll have the opportunity
« Reply #8 on: September 12, 2024, 04:48:22 AM »
What did you decide to go with? I have the solid aluminum mountain on my TA and I have poly on my formula.  I can tell you this. I don't like poly... dang squeaky stuff.  Love my solid aluminum mounts. No harshness at all not sure why they didn't do it from the factory. I guess they figured it out on the 3rd gen as the suspension has the only isolator between the road and the seat.
« Reply #9 on: September 12, 2024, 05:36:06 AM »
I cant remember what I put on the 79, they may be solid but I will check later today. I am pretty sure I have the poly on my 77. Like Luke says, my car has more squeaks than you can shake a stick at. I never considered it being the body bushings? I just thought it was the leaf springs. The ride is nice and solid, just squeaky as heck (almost as bad as my 2014 F 150, LOL).
« Reply #10 on: September 12, 2024, 12:20:41 PM »
I purchased poly. From what I’d read from other experiences the poly body bushings didn't squeak like poly suspension bushings.
Luke, I assume the formula hasn’t been on the road with the poly right?
79GoldnTan
« Reply #11 on: September 12, 2024, 06:20:35 PM »
Put solid on mine plus subframe connectors, no harshness, no squeaks. If you didn't know they were there you wouldn't know. Really tightened the car up
79 solar gold
PTFB SFC
PTFB 1LE
3.08 rear  for now
Lots O Fun
« Reply #12 on: September 12, 2024, 07:27:35 PM »
Well, since I have these I’m going to try them. I planned to give it a shot this weekend and with working 10 hour shifts and 2 kids who knows when I’ll get the chance after this lol
« Reply #13 on: September 13, 2024, 04:52:55 AM »
No, you are right. The Formula hasn't been on the road with the poly body mounts. Kerry, I don't know if the body mounts would squeak as much as all the other mounts do but I wouldn't rule them out. My car has mote than a few squeaks but not horrible. I did lube the heck out of all the poly I installed.  Not saying this is correct but if I had to do it again with the formula and only having the poly mounts on hand I think I would cover them in anti seize to minimize squeaking. Anything has to be better than rubber mounts.  Flexible frame attachment points is such a horrible design.  It doesn't let the suspension actually function as it should, and it doesn't help hold body panel alignment at all. I think  you will definitely see an improvement in how solid things feel once you get them installed
Good luck getting them done. Everything seems to take 2-3 times longer than you think it should. Let us know how it went and how it feels once you get to drive it.
« Reply #14 on: September 13, 2024, 09:59:43 AM »
Poly squeaks and failures are from twisting forces, such as control arms, and a much lesser extent swaybar bushes. Compression forces such as spacers and body mounts don't make a noise or have failures of the same sort.
« Reply #15 on: September 13, 2024, 10:08:52 AM »
Will do Luke.
Ben, that was my assumption but I guess we’ll see what happens
« Reply #16 on: September 14, 2024, 07:03:32 PM »
Welp, this project may wait till later. I got the rearmost ones to break loose without any major issue. The firewall set however gave me a hassle. I bent the cage by mistake and that nut spins on the passenger side. The drivers would’ve done the same had I continued so it looks like the inner wheel wells are coming out. No huge deal but I prefer not to remove them when I can avoid it. That said, I have some work in the bulkhead connector I’d like to do and also want to replace or rebuild (actually just re-plate) my break booster and replace my master cylinder so I may do all of this at the same time which means I’m gonna keep driving the car for now rather than put it out of commission with as little time I have to work on it.
I shall return here when the time comes.
« Reply #17 on: September 15, 2024, 06:55:16 AM »
My car has no panels on it if you need pics showing the firewall area and ways to get at it with minimal fuss.
« Reply #18 on: September 15, 2024, 07:14:14 AM »
That may be helpful if you’re willing. I did have my borescope positioned appropriately so I could see what was happening for the most part. It seems like having the fender removed should give enough room to get in there, but I guess I don’t know for sure.
