Author Topic: '79 Horn plunger(s)  (Read 3923 times)
DeVilliers
'79 Horn plunger(s)
« on: August 12, 2024, 07:22:28 AM »
Hi all,
I call it a plunger, but not sure about the correct name.
There are two(?) plungers on the steering column. There is the one visible when you pop of the horn "cover", and then, once you remove the steering wheel and related stuff there is another copper fitting with a spring inside, connected to a wire. THIS is the one I'm looking for.
Can anyone point me in a direction and some measurements for the part? I need to make a new one, but don't have an old one for reference.
1979 Trans Am
Re: '79 Horn plunger(s)
« Reply #1 on: August 12, 2024, 10:26:46 AM »
See if you see what you’re talking about here. The cancelling cam possibly?
DeVilliers
« Reply #2 on: August 12, 2024, 11:44:29 PM »
Behind the cancelling cam there is a spring loaded copper tube thingy
1979 Trans Am
« Reply #3 on: August 13, 2024, 06:22:32 AM »
Sorry, I don’t know why my link didn’t post. Try again
http://fieros.de/en/articles/steering.html
DeVilliers
« Reply #4 on: August 13, 2024, 07:47:03 AM »
Urg, my picture posting skills have left me.
So, on the attachment, on the 9th photo, where you see the turn signal screws and the lever screws, there is a "silver" button just right of the shaft (at about 14h00).
That is missing and I'm looking to make or buy one.
1979 Trans Am
« Reply #5 on: August 13, 2024, 01:31:46 PM »
That little plunger sits on top of a spring.  This is my 1978 switch.
Parts stores have them for about $45.00 for the whole switch.  Probably cheaper elsewhere.
« Last Edit: August 13, 2024, 01:36:50 PM by wheels78ta »
DeVilliers
« Reply #6 on: August 14, 2024, 12:49:03 AM »
That's the one.
If I can get the outside measurements, then I will be able to make one. The spring hole is not important as that is made to fit.
1979 Trans Am
« Reply #7 on: August 14, 2024, 07:30:44 AM »
I literally just sold a column I could’ve checked for you. If nobody else can help you I’ll pull my column apart and try to get some measurements but fair warning I don’t have a lot of free time so it could take me a while
DeVilliers
« Reply #8 on: August 15, 2024, 02:41:09 AM »
Much appreciated. Maybe someone can help. It's a big job for a small part.
1979 Trans Am
« Reply #9 on: August 17, 2024, 06:23:50 PM »
Ok, so I got into the column tonight. I didn’t pull the turn signal switch out to see if that copper piece comes out the back but it doesn’t come out the front so the measurements I got for you were:
.236” diameter
It sticks out .4”
And I don’t know its total depth however I pushed it in as far as it would go and it goes about .045” in the hole. I have a few pics I could send if you need them.
« Reply #10 on: August 17, 2024, 08:04:46 PM »
There is a tab on each side of the plunger.  They can be bent straight and then the bottom will come out and you can retrieve the spring and plunger that way.  The bottom is connected to a single wire, possibly black, so it won't fall to the floor.
You'll also need to flair out the bottom of the plunger to keep it from slipping out the top.
« Last Edit: August 17, 2024, 08:06:27 PM by wheels78ta »
DeVilliers
« Reply #11 on: August 22, 2024, 01:56:56 AM »
.236” diameter
It sticks out .4”
Thanks for the measurements.
I know how to get to it. To get the correct size made, is the issue :)
1979 Trans Am
« Reply #12 on: August 22, 2024, 08:14:54 AM »
PM me your address and I'll send you the one I have in the picture.  I don't need it and it's just laying around.
DeVilliers
« Reply #13 on: August 27, 2024, 07:04:22 AM »
Much appreciated, but I'm all the way in South Africa :)
Measurements will help a lot.
Thanks for the offer.
1979 Trans Am
