Author Topic: Tachometer not working  (Read 3210 times)
TimBarb
« on: July 27, 2024, 03:13:47 PM »
81 Formula. Finally got the new engine installed and car back on the road. Working on getting some other items sorted out/working. Having problem with tachometer. Tac is doing nothing once car is started…… just stays at zero with no needle movement at all. Noticed that when I’m cranking to start engine, the tac needle reflects the rpm’s during the cranking, but nothing after that. Looking for advice regarding where to start and troubleshoot the problem. Appreciate all the help . Thanks to all!
Re: Tachometer not working
« Reply #1 on: July 28, 2024, 12:53:47 AM »
The tacho is an easy one to test outside of the main engine harness, other than having removed from dash or access to the rear. One wire goes to a live source, the other to the Tach plug on the distributor. That rules out all the other harness and potential issues. The fact it moves when cranking shows it is at least getting signal of some sort, whatever that means. The signal is either lost when not cranking or something else is running through it.
Circuit boards are available for this type, reproduction tachos are not. The large semi-circle type half the size of gauge face is the type used for the Quartz clock/tachs, but that's last resort.
https://www.thepartguy.com/images/products/gauges/6K(80-81)Tach-4.JPG
https://static.wixstatic.com/media/9fd292_5081c4b3ae854d30a7c93b56d8a02a27~mv2.jpg/v1/fill/w_520,h_444,al_c,q_80,usm_0.66_1.00_0.01,enc_auto/9fd292_5081c4b3ae854d30a7c93b56d8a02a27~mv2.jpg
« Last Edit: July 28, 2024, 12:56:42 AM by Wallington »
TimBarb
« Reply #2 on: July 28, 2024, 09:16:32 AM »
Thank You Wallington.
« Reply #3 on: July 28, 2024, 11:17:48 AM »
Test your signal wire coming to the gauge with a test light. It should flash with the engine running. You should have a pink and white wire I believe (may depend on year). It would be the white.
TimBarb
« Reply #4 on: July 28, 2024, 12:17:25 PM »
Thanks Brian.
TA301
« Reply #5 on: July 30, 2024, 02:51:52 PM »
Thanks Brian.
Remove the tach and make sure the tow nits on the reverse side are tight.
TimBarb
« Reply #6 on: July 30, 2024, 05:24:46 PM »
Thanks TA301
79 Moneypit
« Reply #7 on: August 22, 2024, 12:41:31 PM »
Make sure the pink wire to the tach (power) is hot in run.  It sounds like it could be hot in crank only.
TimBarb
« Reply #8 on: August 22, 2024, 08:04:27 PM »
Thanks 79 Moneypit
