Were your previous seals just worn out old ones? Would have been interesting with another brand that was new but a little hard to close or with windows going up and down (on the hull seals) and then changing to the Steele as a comparison.
I see that their body opening hull to door seals are currently unavailable. But they also didn't use the brass inserts for the ends like the door seals do. The hull seals seem to be even more of an issue for tearing away from the mounting pins or deforming, not the small stretched loop on the doors but the entire moulding would shift and pull out of position. Hopefully when restocked they will also be updated.
