Author Topic: Tilt Steering Column  (Read 825 times)
« on: May 13, 2024, 05:41:04 PM »
My Y88 came with a non-tilt steering column.  I want to install a tilt steering column.
What are the differences between the automatic and manual tilt steering columns?
I see a lot of tilt columns listed as automatic trans.  I have never seen a tilt steering column listed as manual.
Re: Tilt Steering Column
« Reply #1 on: May 13, 2024, 07:57:54 PM »
To my knowledge the only difference would be the neutral safety/reverse light switch. An auto version would be that combination whereas a manual version would just contain the reverse light switch. Neutral safety would be accomplished by the clutch pedal switch. The backdrive linkage is different between auto and manual but otherwise I don’t believe the column is different. Maybe someone can correct me if I’m wrong.
« Reply #2 on: May 14, 2024, 07:18:52 AM »
I'm sure the parts can be swapped over, but one that is already from a manual would be so much easier and be like having spares to select from. These days I'd put a kit through one prior to install, new tilt bushes and the like, paint and install.
« Reply #3 on: May 14, 2024, 07:57:14 AM »
Thanks for the info.  I was hoping there wasn't too much difference.
I made an offer and they accepted so the tilt column should be here in a week.
I'll get the kit and make it new again.
