I agree with the previous two posts, however if it is too far forward you may be able to fix without taking anything apart. Very carefully slide the top of the loose panel under the sail panel above, then you should be able to gently tap the entire panel towards the back of the car. It looks like it is a bit brittle (as these things get) so be easy on the tapping part.
