Author Topic: Rear defroster 79 ta  (Read 1551 times)
james.dowling99@yahoo.com
« on: February 28, 2024, 03:06:07 PM »
Hello,I have a question concerning the rear defroster.
I removed my rear window due to scratches,  a lot of them.
I found a better rear defogger glass. The defogger grid has continuity.
I read voltage.  But it doesn't seem to get warm. My old one worked. I do not want to pay for an installation if this glass isn't going to defrost. What am I doing wrong? I am using an infrared thermometer Don't notice a temperature change. Any insight appreciated.
79' Y84 WS6 {wife's}
73' Sedan Deville {Survivor}
75 Delta 88 conv {under construction}
12' Mazda 3I
18' Sierra
Re: Rear defroster 79 ta
« Reply #1 on: February 28, 2024, 09:08:39 PM »
You've tested both ends of the circuit to make sure power runs from wire to wire? The rear glass is basically like a giant fuse, live wire one end, ground wire the other and it heats up instead of blowing, based on the power input.
Did you only use a testlight or run some extension leads to test off car? One end for live power when turned on, the other end that normally ground near the parcel tray needs similar.
« Reply #2 on: February 28, 2024, 09:28:05 PM »
I first jumped it with battery, + to +, - to -. Then laid it in the car, connecting power and ground. It doesn't seem to heat up more than a few degrees. Did this w ignore on, and then with the car running. I Google what temp a defroster should reach, 85 deg is what I cam up with.  I'm getting mid 60s glass was upper 50's before powering up. Green light on Def sw is illuminated when I turn it on.
12' Mazda 3I
18' Sierra
jbanna
« Reply #3 on: March 15, 2024, 12:49:46 AM »
I replaced my rear window about 30 years ago, with a junkyard one, and it has worked great ever since; however, I did have to repair a couple of the grids with a kit readily available at auto parts stores - if you do it right and test the resistance on the "unbroken" grids, you should have the same results - there can be breaks not easily visible...
