Author Topic: Brake pedal sticking to the floor with delayed release.  (Read 5208 times)
glhx
« on: February 26, 2024, 05:59:49 AM »
Brake pedal is sticking in the down position after replacing the proportioning valve and lines.
I just replace everything from the booster back.
Calipers, rotors, booster, master cylinder…..
All of it.
I had a soft pedal before all of that. But it wasn’t sticking to the floor until the lines and the p valve.
Now I press the pedal down and have to help it back up. It sinks to the floor and sticks there. I have to pull it back up with my foot.
The car does stop but not well. I’m not sure what’s causing this.
I will add that when the car is in idle. The pedal return. It’s only when I’m actually running and stopping that it does this.
Re: Brake pedal sticking to the floor with delayed release.
« Reply #1 on: February 26, 2024, 06:13:27 AM »
Several potential reasons, Google will cover most since they are all simply ideas that you need to check to confirm. Generally it's an issue with the master cylinder leaking past the seals, air in the system also as a result of first, leaking seal at a cylinder or caliper. Look for obvious fluids leaks, also look for fluid loss, or gain in reservoir where air has entered the system somewhere and stayed elsewhere. Did you bench bleed the mc before installing? Complete fluid renewal and bled from furthest point forward? Don't drive it until sorted.
tinpusher
« Reply #2 on: February 26, 2024, 09:49:10 PM »
It almost sounds like the seals in the master cylinder were maybe installed backwards?
Maybe the spring in the master cylinder is not correct and too weak to retract the piston?
The only other thing that might cause some kind of fluid lock would be the proportioning vale being offset.. meaning, not using the valve centering too to hold the valve in the correct position while your bleeding the system.
My guess is that you received a bad master cylinder.
tinpusher
« Reply #3 on: February 26, 2024, 09:55:08 PM »
This is the centering tool if your P.valve didn’t come with one.
« Reply #4 on: February 27, 2024, 01:58:29 PM »
I think it has to be the booster.  The MC is actuated by a little pushrod that doesn't connect, so you couldn't pull the piston back no matter what you do.
Air in the lines would help you (by acting as a spring attached to the piston), so that may be a problem, but it's not "the" problem.
tinpusher
« Reply #5 on: February 27, 2024, 07:15:34 PM »
Did you get the correct P.valve? There is one for disc/drum and one for disc/disc. I have read somewhere in the past about the wrong P. Valve holding pressure after it’s activated….just throwing stuff out there
glhx
« Reply #6 on: April 30, 2024, 12:59:12 PM »
I replaced the master cylinder with a new one and bench bled it.
The master cylinder problem is solved and the pedal not returning is solved.
However…….after fixing this. The pedal was back to very soft. It had been like this for a long time now. Long enough to not drive the car for a while.
I replaced everything. Power booster, lines, proportion valve…..calipers all 4 corners.
The pedal was still soft.
I adjusted the parking brake for the rear disc to 1/16” of an inch to activate. You pull it 1/16th and it grabs. I think 1/8th could be ok but I don’t know. I saw where 1/16” was where it should be.
Either way. The parking bakes are adjusted well and I have a very good understanding on how to do that.
So……I still have this soft pedal. I bleed the brakes over and over and over again. The fronts bleed fine. Quickly and done.
The rear passenger  side bleeds fine. Takes a while…..but bleeds fine. No air whatsoever. Not even the smallest bubble.
The drivers side rear however. I bleed it and over and over again small puffs of air keep coming out.
So
I got some Teflon tape and wrapped the bleeder screw very thick so it would seal while being open and not draw air into the threads. I then got some 3/16 clear vinyl tubing and ran the tubes from the open bleeders all the way to the master cylinder.
I did this to both back calipers.
The passenger side……no bubbles.
The  drivers side however…….would not stop pulling air. Pump after pump…..probably 200-300 pumps of circulating fluid. It kept pulling big 1” long bubbles of air over a timed sequence.
As soon as the air was pumped back into the master cylinder. Another 1” of air would come out the tube from the caliper.
So what this means is that my drivers side caliper WONT LEAK FLUID. But will pull in air and not allow me to bleed the system.
With both calipers hooked up at the same time in the back to the 3/16” tubing. It’s only the drivers side that pulls air. I checked all connections and they are tight.
This is a new caliper from O’Reilly.
I have caliper cores so I know what the system looks like and exactly how it works.
I guess…….its pulling in air from one of the 2 seals?
There is a check valve on front of the piston but no fluid is coming out of it. Which I don’t think fluid is ever supposed to come out of it. I think it’s meant to get rid of air behind the piston and not let any back in. I will add that when I took the check valve off. It had some rust under that seal.  Not much but some.
So……I have warrantied out the caliper hoping the new caliper will be sealed.
What do you guys think is acceptable for for inches of travel for an e brake adjustment?
1/16”
1/8th”
And
Why or how do you think that one side is not leaking fluid but is pulling air.
Keep in mind……every part of the system is new. Hoses…..brake lines.
All of it……
It’s just this one caliper and it has cost me about 15 hours to diagnose.
I will add that putting in that clear vinyl tubing and pressing the brake pedal over and over again has helped a lot to figure the problem out and instead of using my pressure bleeder in this car. I will be using this method. As it cycled the fluid over and over until the air was gone
At least in 3 calipers.
If I can get that drivers side to stop pulling air. The system will work to 100% again.
« Reply #7 on: May 01, 2024, 01:44:57 AM »
The correct fitting doesn't need Teflon tape, perhaps the more you add, the more it can't seal.
glhx
« Reply #8 on: May 01, 2024, 07:53:27 PM »
I’m not sure what I could have put in that caliper with a nipple on it to Receive hoses.
That Teflon tape was a tight fit.
The threads took a 3/8 coarse thread bolt.
I think that caliper was pulling in air through the e brake. I’ll know more when I put the new caliper on there.
glhx
« Reply #9 on: May 08, 2024, 12:13:53 PM »
I went ahead and put a new caliper in there.
Picked up an extra bleeder screw and drilled out the center. Then seated it.
Ran a hose back to the master cylinder and bled the system. There was still a lot of air in the system.
After about 200 pump and air coming in over and over.
I put the original bleeder screw back in with the hose connected to it running back to the master cylinder.
I bled it the normal way. I pumped it up 3 times. And released the bleeder screw. A lot of air came out.
I pumped it up 3 more times with the bleed screw tight. Then released it. No air came out.
I then pumped it up again and did the same thing. Air came out
So this is a timed leak. Ever other cycle of pumping it up 3 times. Adds in a lot of air.
At this point I’m kind of at a loss. I’ve never had a brake system do this.
I’ve replaced the entire system and I cannot get it to bleed. I don’t think it trapped air I’m not getting out. I think it’s air being introduced into the system over and over again
tinpusher
« Reply #10 on: May 08, 2024, 08:41:52 PM »
After reading this post again, are you doing the brake bleeding by yourself? Or do you have a helper?
You should have two people performing this task, one pressing and holding down the brake pedal, then opening the bleeder, then close the bleeder while the pedal is still down, then pump and hold down and repeat the process. What I read, it sounded like you were trying to do this by yourself… just asking.  If you are doing this by yourself, then you’ll keep pulling air around/ through the bleeder because your not sealing off the system at each pressure change. Teflon tape should never be used around the bleeder.
I also wanted to make sure that your bleeder is facing up.. I heard of some trying to bleed their system with the bleeder facing down. I don’t want to come across as being condescending, just trying to cover all angles to help resolve the issue.
glhx
« Reply #11 on: May 10, 2024, 02:08:57 AM »
Yeah, I’m bleeding it myself.
I have long runs of 3/16” tubing tightly sealed to the bleeder screw.
They run the length of the car back into the master cylinder.
When you bench belled a master cylinder. You run the master cylinder outlets back into the reservoir.
I’m doing the same thing. I’m just doing that with the entire braking system.
I should be able to pump as many times as I want and the air finally bleed out of the whole system.
The Teflon tape was only used to seal the threads with the bleeder screw open. And just for this style of bleeding. Because a loose screw can pull air back into the threads. This Teflon tape prevents this. Toy don’t leave the tape there permanently. It’s just for this style of bleeding for air creeping into the threads. Some people use grease to do this but grease is ineffective. This is a very solid way to bleed a system. Probably the best way but not commonly done because it uses a lot of extra fluid to fill the hoses. I’ve used it many times. It’s a sure way to get every little particle of air out. Only a pressure bleeder might be better. It’s basically bench bleeding the whole car instead of just the master cylinder. Same concept.
However……I added a bleeder screw that was drilled out. This closed off the threads and no tape was used. It just allowed free flow out of the screw into my long run of 3/16” tubing. I only did this and got rid of the tape, so I wouldn’t have the tape to blame. The threads were sealed tight. This 3/16” hose was sealed tight.
I also did this with a 2 person style. The normal way……
Just to prove it’s air coming in from somewhere else.
And here…..right here. Shows the problem. The air still crept in even with the normal 2 person style. I still had the hose sealed to the bleeder screw so I could watch the air come out. This shows for certain there is air coming in the system. I just don’t know where yet.
There can be only a few places.
The passenger side rear line with its 2 connections.
Or the 3 seals in the caliper.
The parking brake seal on the shaft.
The piston ratcheting o ring
Or the main piston seal.
It’s a complicated caliper
I haven’t taken the caliper apart yet. Often times the rebuild these and leave the pits in the caliper. Sometimes they leak fluid.
But these were 2 new calipers from oreilly. They shouldn’t leak.
I’m just seeing if anyone else has had this problem specifically. I’ve seen the Eldorado guys have it a few times but nothing really came of it.
I’ve also seen where they put front calipers on the back and get rid of the parking brake all together.
I’ve got a good parking break adjustment. I just can’t get the system to not pull air every time I step on the brake 6 times.
tinpusher
« Reply #12 on: May 10, 2024, 05:05:15 PM »
Ok, now I see what you’re doing…I didn’t understand the drilling of the bleeder, now I do, never did it that way.
It doesn’t make sense that you’re pulling in air and not leaking fluid. Once you push on that pedal, your fluid pressure would be several hundred psi and fluid would be spraying everywhere.
I have the stock 4 wheel disc brake set up and only had one issue with the MC. Maybe do a gravity bleed over a few hours, then close the system to see if it makes a difference?
tinpusher
« Reply #13 on: May 10, 2024, 05:30:01 PM »
I know that your MC is new, but you might want to pull it away from the vacuum booster enough to check for dampness. No need to disconnect any lines to check. I haven’t had much luck with the reman stuff. I remember when we would just rebuild these ourselves with a hone and rebuild kit.
