Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
TAC Tech
Tires, Brakes & Suspension
Which axles should I upgrade to?
« previous
next »
Pages: [
1
Author
Topic: Which axles should I upgrade to? (Read 2271 times)
glhx
on:
February 19, 2024, 10:49:17 AM »
The car is a rear disc car factory and street driven. No racing
The seals cut into the axles and left a deep groove. I put a new seal in that was offset some but it didn’t work well. It still soaked my brake pads in 90 weight.
So I want to get new axles.
I’m looking at moser A102803.
It shows them to be 30.06
Where as other companies show 30.125
One concern with moser is the lug studs.
They sell 1 1/4”
And 1 3/4”
The studs on my stock wheels are 1 1/2”. They don’t sell those
Moser tech support says I can run 1 3/4” studs and the factory lug nuts will tighten fine. I didn’t hear a lot of confidence in his voice.
I’m wondering if the lug nuts for the snowflake will accept that extra 1/4” for the back wheels
Or……..
What axles do all of you buy for upgrades? I’d like to know and I’ll run the best axles I can.
76Tranz
Re: Which axles should I upgrade to?
Reply #1 on:
February 19, 2024, 02:26:06 PM »
When I replaced my axles and posi unit I contacted (tomsdifferentials.com),Ph.# 208-265-8111. They have everything you need and will put the lug studs in for you just give them a shout and they can set you up.
Reply #2 on:
February 19, 2024, 07:10:13 PM »
Not sure which version snowflakes you have, several brands of lugnuts exist and probably have different specifications. Take one off and measure the thread depth on a 7/16" UNF bolt.
Reply #3 on:
February 19, 2024, 07:21:15 PM »
I went with Dutchman axles when I upgraded my axles for my LS3. Everything worked out well. No issues with my Snowflake wheels either. I went with their SR62 model 30 spline axles.
https://dutchmanaxles.com/products/stock-replacement-axles/gm-axles.html
glhx
Reply #4 on:
February 19, 2024, 09:18:21 PM »
Did your car come with the 30 spine differential?
Reply #4 on:
Reply #5 on:
February 20, 2024, 07:55:35 PM »
I’m running an aftermarket Eaton TrueTrac diff.
Reply #6 on:
February 21, 2024, 03:53:20 AM »
I went with Moser no issues. Only the hub wasn't long enough to hub center the wheel.
Reply #7 on:
February 21, 2024, 09:38:14 AM »
If they are aftermarket snowflakes then they use the wrong bore to match anyway. Of course, rear discs axles are different length again.
Reply #7 on:
Pages: [
1
« previous
next »
TAC Tech
