Not so much a refurbishment but I had them apart and thought maybe others might find of interest. One of those components that you can imagine pulling apart and never go back together or work again, but these are surprisingly simple.
I have done minor plating in the past, mixed results with more setup than I could justify, and didn't like having old fish tanks around! The current guy I use is still not local, in another state of Australia but has been handy in the past and happy to post back and forth at cost. I do a batch every 1-2 years. It generally involves several packets of assorted nuts, screws and clips, perhaps a few fittings or custom pipework, homemade tools and the like. All trivial things now. Have done larger items like seat tracks and brackets, vacuum diaphragms, fuel caps, shifter assembly parts, window track parts, ashtrays and reverse linkage components. Some are to original finish, others just to look neat and fancy. But mostly just little projects as nothing else is making progress. I do have a few assorted chemical blackeners too, depending on the part and make but large scale is easier to buy new bolts than blacken a bucket of originals. I still do some here and there, often touch-up.
Far too many decent original parts early on were sandblasted to powdercoat or scuffed back badly with a wirebrush to paint, when could have simply been replated. Live and learn.
Some random pics, not so much to document but also offer a guide to what I sent when the guy is trying to sort through packets of almost identical screws but are in different finishes. Even looking back there were errors, the bolts were not meant to be sent with the trunk latch or plated. The trunk latch, and hood latch, were later sprayed a cast iron/grey oxide outer but still has the gold plate mechanicals. I had a few minor things that I've replated only to realise my original sample or pics were so faded that the gold had gone grey and looked faded silver, resend and replate to the other, or send a spare for whatever I feel like when the time comes, if it ever comes. And a few times have found original GM parts to be either gold or silver. The 74-78 brake light lens screws shown were one example that existed in both. Other things like brake line retainers over a diff and hood pull cable retainers are items I've collected that have been blackened on some cars and plated on others, so I've often restored in same to give options.
Gold cad plating parts1 by
Ben, on Flickr
Gold cad plating parts completed by
Ben, on Flickr
Silver zinc plating After 6-5-19 by
Ben, on Flickr
Firebird shifter 3spd replated1 by
Ben, on Flickr
RH side bucket seat base tracks by
Ben, on Flickr
