Author Topic: Idle Stop Solenoid  (Read 799 times)
Idle Stop Solenoid
« on: January 22, 2024, 03:04:12 PM »
Does anyone know if the Idle Stop Solenoid is only used on cars with A/C? or did all of them get it.
79 Trans Am.
Re: Idle Stop Solenoid
« Reply #1 on: January 22, 2024, 04:09:47 PM »
I believe in 79 AC only. Other years used it for additional purposes
« Reply #2 on: January 23, 2024, 05:51:20 AM »
Thank you.
« Reply #3 on: January 24, 2024, 05:25:32 PM »
For '79, it would have been used to compensate for the AC compressor load, yes. Bear in mind that they don't have enough juice to actually overcome the throttle return spring tension and move the throttle lever by themselves. After you switch the AC on, you need to rev the motor up so that the solenoid plunger can extend and then hold the throttle lever at the desired position once you take your foot off the gas.
« Reply #4 on: January 24, 2024, 06:37:19 PM »
Thank you for the explanation. Makes a bit more sense.
