I'm confused. They are functional. Airflow and heat enter via grilles and radiator can then exit via the fender openings. The shape of the vents on the outside are also functional at speed in creating a low pressure point at the rear edge, albeit if extended more, and larger opening, would be more substantial. What are you seeing in yours? Trying to put exhaust out it?!
