Author Topic: Widest 15" wheel and tire combo(yes fronts also)  (Read 1969 times)
NBF823
« on: January 01, 2024, 11:26:13 AM »
Whats the widest 15" wheel and tire combo I can shove under this car?
Is 15x9 265/50R15 front, and 15×10 295/50R15 rear possible?
I know that those will fit in the rear on 8"wide 4" backspacing.
So 15x9 4.5 bs front, 15x10 5" bs rear?
And has anybody tried a 15" American racing 200s with 11.75 C3 rotors and Afco F88 4 pistons? Im using C5 conversion knuckles and K6024 truck upper balls.
I know guys pushed the limits of 15" wheel and tire combos back in the day, I'm just seeing if anyone still know what fits.
Thanks.
Re: Widest 15" wheel and tire combo(yes fronts also)
« Reply #1 on: January 01, 2024, 04:51:54 PM »
Will need to pack out the steering stops or will scrub on sway bar and possibly inner fender of both depending on height and suspension.
« Last Edit: January 01, 2024, 05:44:36 PM by Wallington »
NBF823
« Reply #2 on: January 01, 2024, 09:44:14 PM »
Thanks.
I'll have to fit up the sway bar. I built cribbage which i need to utilize to fit everything.
The inner fenders are not currently in the car as I planned to make them from glass or cf.
I know a 295/50 will turn lock to lock with no fenders on an 8" rim - i was just checking the roll cage clearance there.
I dont mind modding the lower A,sway, or inner fenders, I just dont want to alter the exterior skin short of some fender rolling.
JJ 109
« Reply #3 on: January 03, 2024, 09:58:51 AM »
Not a problem but I prefer more BS on both.
Best to measure but 5-5.5” range I have found works best.
JJ
76 pro tour project
Twin Turbo LS1
Detroit
NBF823
« Reply #4 on: January 03, 2024, 10:13:14 AM »
