Author Topic: Hood scoop to air cleaner gasket  (Read 2560 times)
TA301
« on: October 09, 2023, 01:41:09 PM »
I can't seem to find this part as a reproduction. Does anyone have a source? The gasket I am referring to is the one the retaining ring meets at the air cleaner brim.
Re: Hood scoop to air cleaner gasket
« Reply #1 on: October 09, 2023, 05:31:35 PM »
This thin piece of rubber/foam?
https://www.amesperf.com/parts/4287/
« Reply #2 on: October 09, 2023, 07:31:32 PM »
You mean this one inside lip of shaker adaptor ring? #527230. It changed profile a few times, being solid or hollow, ended up crushed flat and hard, no grip and shaker turned. No one 'really' sells it, although they often market a generic rubber seal that may fit and do the job. Nothing special, adhesive-backed and keeps shape, but just thin enough that the clamp can slip over it to begin with.
I'm not sure what the Ames seal is meant to be, or the application years which don't make sense. So maybe there's something else, like regular air cleaner lid seal.
https://www.firebirdnation.com/threads/shaker-scoop-gasket.568991/
shaker3 seal1 by Ben, on Flickr
GM NOS 527230 shaker base adapter to aircleaner seal TA (2) by Ben, on Flickr
« Last Edit: October 09, 2023, 07:35:24 PM by Wallington »
TA301
« Reply #3 on: October 10, 2023, 05:38:02 PM »
TA301
« Reply #4 on: October 10, 2023, 05:41:27 PM »
Yes, that is the one. I find the scoop moving about at idle with the hood open, as annoying.
