Author Topic: Bleeding rears only  (Read 706 times)
Bleeding rears only
« on: October 03, 2023, 05:45:03 AM »
Has anyone had to change a rear brake hose or disconnect something but not bleed it straight away? I have a rear hose to swap, but wanted to powdercoat the rear bracket while apart with a batch of smaller items at same time. In theory, could be 1-2 weeks from quick disconnect and refit new hose, then disconnect again, insert bracket and refit hose again. I could jack the rear up fairly high, for access also, but to limit any air bubbles from going anywhere except towards the rear drums, but also, bleeding the fronts is a pain! Anyway, more for conversation as I would anyway, just had me thinking how many actually would and get away with it.
Re: Bleeding rears only
« Reply #1 on: October 03, 2023, 08:07:20 AM »
I'd just plug the line with a homemade fitting welded shut or use a rubber plug. Then bleed as normal when ready.
« Reply #2 on: October 03, 2023, 08:49:45 AM »
It would be fully connected once hoses swapped, it's just that the the hose passes through the mounting bracket which will be missing for a  week or two. Otherwise, only disconnected for several seconds each time. Only a workshop shell, doesn't even matter if has brakes, just be easier to sell if does.
