Author Topic: Power steering  (Read 1007 times)
apfstg
Power steering
« on: September 29, 2023, 05:27:13 AM »
My 1979 has had 403 replaced with 1977 400 and the pressure line leaks at gearbox
Online search is confusing because the couple that I think would fit seem long compared to original,
Anyone know what hose I should buy?
Re: Power steering
« Reply #1 on: September 29, 2023, 05:52:33 AM »
If now using PS and brackets to suit a 400 in a Firebird, then the parts should match, as if it was an original item.
A quick search says it should be possibly #7816969.
And 2 random links, does this look right? Also, there were 2 different length 403 PS lines, early and late. I think they both work but just a revised shape and position. Not sure, mine is custom.
https://www.firebirdcentral.com/1971_1979_Firebird_Power_Steering_Pressure_Hose_p/pow-2025.htm
https://www.thepartsplaceinc.com/product/1979/1979-pontiac-firebird-transam-high-pressure-power-steering-hose-gm-7816969/21610
Pontiac engine power steering hoses diagram by Ben, on Flickr
« Last Edit: September 29, 2023, 06:47:26 AM by Wallington »
apfstg
Re: Power steering
« Reply #2 on: September 30, 2023, 05:51:19 AM »
Yes, mine is routed down from pump instead of up like the picture, so the length made me wonder
I think the steel part was mostly cut off when someone fixed leaking connections with fitting
My motor does have the 19 1/2 fan and shroud from olds motor so questioning which other parts that have been combined before a purchase
I knew when I looked this morning I would have a direction and an answer thanks!
Re: Power steering
« Reply #3 on: September 30, 2023, 06:58:31 AM »
Unless it's the Olds hose. You could try tightening and loosening several times then tighten a little more, see if it makes a better seal.
Warren Seale
Re: Power steering
« Reply #4 on: October 01, 2023, 06:18:44 AM »
Make sure the flair on the hose fitting and on the gear box is clean.  Any dirt on those mating surfaces could prevent a good seal.
79 T/A,WS6,403,A3
96 T/A,WS6(#1344),M6
72 442,W30,A3
Re: Power steering
apfstg
Re: Power steering
« Reply #5 on: October 01, 2023, 07:10:33 AM »
Someone put a ferrule fitting on pump end but it’s not tight on tube so the tube must have lost size due to rust - I don’t think it’s metric or hope not
I ordered a hose if it doesn’t work I’ll have one for sale (haha)
Re: Power steering
« Reply #6 on: November 09, 2023, 12:29:58 AM »
Did you get this sorted, or still more projects to get to?!
apfstg
Re: Power steering
« Reply #7 on: November 09, 2023, 07:11:29 AM »
Replaced hoses and no leaks . The power side hose took a little moving around to get it into shape that works
Would’ve been easier before new radiator went in but I like swearing at myself
Re: Power steering
