Author Topic: Radiator mounting  (Read 1980 times)
apfstg
Radiator mounting
« on: September 19, 2023, 04:53:55 AM »
Replaced radiator support and battery box on my 79 . when I removed plastic shroud radiator was just sitting on support only hooked by hoses.
Purchased aftermarket aluminum radiator and rubber mounts but confused on what actually holds radiator .
Are there brackets that bolt to radiator support to position radiator? Pics or breakdown that I’ve seen don’t really show set up
About to build some sort of braces but tend to get carried away and overbuild. Any help appreciated
Re: Radiator mounting
« Reply #1 on: September 19, 2023, 05:09:04 AM »
The radiator is held in place by the fan shroud. It sits on those rubber isolators in the fan shroud.
