Author Topic: Help with no start / no crank  (Read 826 times)
a-train
« on: August 11, 2023, 04:27:34 PM »
Hoping for some advice.  I have a 1980 Trans Am.  The last time I drove it, which was last fall, it started with no issues.  Last week I was prepping for a show and went to start it and had no crank.  No sound from the starter at all.  Checked battery, cables, everything seemed good.  I thought maybe the started kill on my alarm had went bad so I checked the starter kill relay.  One side had power, but not the other.  I made a jumper wire with a 20A fuse to bypass the starter kill relay.  Still no crank and popped the fuse right away.
I pulled the starter and the solenoid terminal showed grounded to the case.  Dead short.  I ordered another starter and got it put on today.  Same issue.
Where I messed up was not checking the solenoid before I installed it.  So now, I’m trying to figure out if my new starter is bad or if I have something grounded out somewhere.
Under the hood looks ok.
Any ideas?
"I thought I smelled orange"
aussieta
Re: Help with no start / no crank
« Reply #1 on: August 11, 2023, 07:25:01 PM »
put a socket on the crank bolt and check that your engine can turn over by hand
inspect the wiring to the starter motor for mouse nibbles
1978 Y84 W72 WS6
« Reply #2 on: August 12, 2023, 04:29:29 AM »
Use a screwdriver and hot start using the starter. That will bypass everything and show that the battery is holding power to start the car.
aussieta
« Reply #3 on: August 12, 2023, 04:38:36 AM »
what if the starter is shorted out
and you weld your screwdriver in there
1978 Y84 W72 WS6
