Author Topic: Fan Blade/Clutch  (Read 1736 times)
Fan Blade/Clutch
« on: June 19, 2023, 06:18:47 AM »
Trying to get the fan blade and clutch ordered and have run into a bit of confusion. I dont see anything motor specific in Ames, summit has generics. Not sure what to order I figured I would call summit and ask someone there. Unless anyone here has better advice. Also How does this mount to the front pulley? My 77 looks like it must have some kind of stud that threads into the water pump and the fan bolts to this with some nuts. I havent been able to find these either. Below is a pic of how its attached in my 77. I dont know if this is right or wrong.
2023-06-19_08-14-37 by Kerry Grubb, on Flickr
Re: Fan Blade/Clutch
« Reply #1 on: June 19, 2023, 06:38:03 AM »
My 77 is the same as far as water pump studs. When I replaced my pump last time my engine was out it didn’t come with the studs so I had to move them from the old pump to the new.
As for the clutch, Hayes seem to make good units. Is the 10th an AC car? If so may want to consider a HD clutch vs the SD but I ran an SD on my 77 for a while with a 5 blade fan before I reinstalled my AC and it did the job just fine. Now with AC I tend to start to warm up at idle, possibly because I’m running a 403 shroud on my 400 and wonder if the fan depth isn’t right but either way, a 7 blade fan and HD clutch slowed the warming up at idle with AC on. Didn’t stop it though. No AC, I rarely see 185° under any conditions.
« Reply #2 on: June 19, 2023, 06:56:14 AM »
Thanks, yes its an A/C car. My 77 is also but not hooked up. I am going to try and hook it up on this one though.
« Reply #3 on: June 19, 2023, 02:41:17 PM »
There's a pilot on the water pump and 4 studs.  The studs are a curiosity as they are fine thread on one end.
The original clutches weren't slotted like that one, so that one is a newer one.  They don't really last.  I've never seen a good old one.
jk79ta
« Reply #4 on: March 21, 2024, 07:56:36 AM »
I know this is an old thread but thought I would tag on instead of starting a new one. I'm trying to remove the fan and clutch to remove my radiator. Can anybody tell me, do you remove the 4 nuts that are on the water pump studs? Mine looks just like the picture, with slots.
« Reply #5 on: March 21, 2024, 08:03:25 AM »
Yes, remove those 4 nuts and the fan and clutch will come off together.
jk79ta
« Reply #6 on: March 21, 2024, 08:48:28 AM »
Great! Thanks, the whole shaft spinning isn't an issue?
« Reply #7 on: March 21, 2024, 06:04:27 PM »
Not as long as the belts still have tension. The water pump pulley may become crooked but it shouldn’t slide off at all and the belt tension will hold it still.
apfstg
« Reply #8 on: March 22, 2024, 11:43:05 AM »
Just wondering , are those studs available anywhere? Any over length and the pulley won’t spin .mine had one short bolt with a couple extra washers on it
« Reply #9 on: March 22, 2024, 12:23:49 PM »
They'd fit millions of GM cars made in the fan clutch era, so I would think so.  Looks like Dorman and MTC make them, at least.
