Author Topic: Help With Timing Modifications  (Read 585 times)
Zach
« on: May 05, 2023, 08:28:19 PM »
Howdy all, digging into another thing I have 0 knowledge on, first was the carburetor, now onto timing. Car is all stock in what matters. Issue is it’s idling too high for where curb idle screw is, most likely because initial is 18 degrees on a 77 400 for its low compression. Posted the issue on cliffs forum and he said he recommended lowering initial and changing total timing. Curious if you guys have any resources or guides I can look through to know what I am doing. Idea in my head is to square off transfer slots on the carb so transition is as smooth as possible, then lowing initial timing till I get the rpm I need, 775 for a manual in this case. I believe this will set me around 8-12 degrees last time I checked, I will consider this my initial timing. I’m assuming with HEI I need to replace the springs and weights to achieve 36 total, unless someone can tell me what is optimal for a 400, got this number from a quick search. From what I have read vacuum can should be fine since it’s only for cruising. Curious if this is the right way to go about this, would love to hear input.
Re: Help With Timing Modifications
« Reply #1 on: May 05, 2023, 09:48:56 PM »
I will preface this with I’m not an engine expert. However my first few thoughts are, factory spec is 18° BTDC as you mentioned. That said, these cars rolled off the assembly line and idled just fine. Something has to be amiss to cause your high idle. Second, obviously idle can change depending on ignition timing but I feel like you’ll be chasing yourself in circles and putting a bandaid on a bleeder if you’re attempting to set idle by altering timing.
That said, I know you’ve been through this before but refresh my memory, have you eliminated all vacuum components to test your idle? That may give you a good starting point if not. Pictures and video are worth a thousand words sometimes. I seem to recall you, or someone else, questioning your timing mark. Ever verify it is correct?
Random thought, you’ve attempted to adjust via the idle screw but have you checked how tight the throttle cable is? Ever try disconnecting it to see if your throttle closes further? Just trying to brainstorm. And I don’t pretend to be smtarter than Cliff, or a lot of people. He’s far more knowledgeable than I am with these engines with personal experience driving that knowledge. You should remember though, with the exception of modern gasoline being of different quality than 1977, there’s no reason why a stock setup engine shouldn’t run with factory settings. Just some thoughts to start things off. Not everyone may agree with me and that’s ok.
Zach
« Reply #2 on: May 06, 2023, 12:05:57 AM »
I should say the car runs absolutely perfect and idles great I just have a small hesitation when it comes to coming on and off accelerator notably when trying to smoothly shift or coming to a stop, WOT banging gears it runs perfect, which I assume is cause my throttle is set to completely close, closing off transfer slots, very small issue. Through research I found squaring the transfer slot is what people say to do to get the best performance, I am wondering what stock configuration was off the assembly line, cause technically it does hit stock specs but this is with throttle blades completely closed.
Yes, that was me questioning my timing mark, I checked and it is accurate, harmonic seems to be good. Although, I will verify mech adv is working properly, and verify total timing now that I know how.
I checked almost everything in terms of a vacuum leak, the only symptom of a vacuum leak I have is a slightly high idle compared to where the throttle is +50-150 rpm. All the lines seems to be sound, closing choke blade will kill the engine pretty quick, I never checked things like the TVS, EFS, EFS check valve, unsure of a safe way to check, I assume the carb wouldn't run the same with everything removed. In terms of throttle cable/blades, I had them re-bushed and rebuilt by Cliff, so I assume they are as close to good as they can get. Throttle physically can't shut anymore, throttle cable has enough slack to not pull and the return springs are still pretty tight. Only issue there is my blades are deteriorated and letting too much air through, I would assume Cliff would tell me this though.
Any input is good input, I know the least of anyone here so anything is helpful. 2 out of the 19 years of my life have been dedicated to this car so far, accumulating what ever I can find online.
After a few hours of research I think I am going to abandon the idea of changing the timing, low end would most likely take a hit due to low compression, 18 degrees is needed to make it feel snappy off rip. Although, I am still willing to hear what people have to say.
Zach
« Reply #3 on: May 06, 2023, 01:57:38 PM »
Alright I feel like an idiot, I have been reading the timing tab wrong, since it isn’t marked I forgot how to count and have been running 20-21 degrees BTDC. Set it correctly to 18, even marked it just to make sure. I was able to utilize the idle screw now that the timing dropped my rpms and retuned the mixture screws. Running much smoother on and off throttle.
« Reply #4 on: May 06, 2023, 05:39:05 PM »
Trust me, I’ve made worse mistakes lol. Glad you got it figured out! Keep at it man, that’s how you learn.
