Author Topic: Door VIN and tire stickers  (Read 6522 times)
pozarcar
« on: April 29, 2023, 04:19:37 PM »
Before the Great Crash, many TACers found files posted in Tips & Tricks useful to make their own customized versions of the VIN sticker, tire info sticker and Hurst t-tops conversion sticker that many 2nd gens had on the driver's door jamb.  I originally used MS Word to make some for myself back in like 2006 or so, and posted them.  Another forum member eventually significantly improved upon my original, making editable .pdf files.
I would like to make these available again to Forum members, but I don't believe I can attach .pdf files.  If one of the Mods could contact me I'm happy to provide the files to be posted.
1978 Y-82 SE 4-speed (1 of 489)
2010 Plum Crazy Challenger SRT-8
Re: Door VIN and tire stickers
« Reply #1 on: April 30, 2023, 05:35:53 AM »
That would be great. I remember someone, maybe you, even posted the paper/plastic adhesive sticker material and where to get it.
Mac
« Reply #2 on: May 01, 2023, 12:54:41 PM »
I have couple of files window sticker and build sheet you can edit if they fit your needs. I can't load word or excel files, so pm me if you're interested.
The Never Ending Punch List!
Maxthe222
« Reply #3 on: May 03, 2023, 06:21:19 PM »
It's great you do that, as there is also a company who is remaking the door stickers and charging hundreds for them. I think I saved a copy of your files a while back
1987 T/A GTA L98
1979 T/A Y84 WS6
1979 F/A W72 WS6
1978 T/A L80 WS6
1978 Formula L80 W50
1971 Formula 400 4-Speed
« Reply #4 on: May 03, 2023, 06:52:38 PM »
That's when you pay for the official tamper-proof GM-licensed versions.
There's also plain stickers with text you need to fill in with your own details, which is probably beyond most capabilities of setting up and printing correctly in one attempt. If I was printing anything I'd likely want to print the lot.
There was a guy that did the clear window original version way back, probably still does somewhere. I had several done, different tyre size options. I probably have the other data now if I wanted it but think I used general info. They were $27 each, which was expensive years ago for several plus postage. More so when the one I used was dropped on the garage floor, then attempted to brush off the dust and grit and still attach to door. Those clear windows are also good for air pockets and sand display.
« Reply #5 on: July 27, 2023, 04:13:25 AM »
Any updates on these, or are they on other forums? I just had a guy ask me about them, needs to make a set to get car registered.
