Author Topic: Shims at core support and upper fender  (Read 775 times)
Updated71
  • TA Addiction
« on: January 20, 2023, 02:33:37 PM »
I'm not anywhere near my body manual. If I remember correctly, no shims should go between the core support and upper two front fender bolts on the early cars. How would  get the core support to come up a bit to meet the fender so as not to pull it down?
I did this so long ago I don't quite remember.
Re: Shims at core support and upper fender
« Reply #1 on: January 25, 2023, 12:21:50 AM »
I don't recall any being called out officially, it was more for fine-tuning a fit.
Updated71
  • TA Addiction
« Reply #2 on: January 25, 2023, 04:10:58 AM »
Thank you.
« Reply #3 on: January 25, 2023, 07:02:50 AM »
Agree with Walli, I dont know if shims are posted or not. I would set the core with the correct mounting hardware and then go from there. Shim as needed to get things aligned.
Updated71
  • TA Addiction
« Reply #4 on: January 25, 2023, 05:23:23 PM »
Got it. Thank you all.
