Author Topic: 1980 Trans Am (New Wiring Quetion)  (Read 1010 times)
d_hache
« on: January 08, 2023, 09:49:39 AM »
1980 Trans Am (New Wiring Question)
I am currently restoring a 1980 Trans Am.
The existing wiring is not to bad but I decided to go with a new replacement,.
There are a few options online but I am not sure which one I should get.
I am sure that someone in this forum has replaced the entire wiring harness in the Trans Am before so wondering what might have worked well for you?
Any input would be appreciated.
PS.  Here is a picture of the car going into the new garage at the back I built to complete the restoration.
Steve B
Re: 1980 Trans Am (New Wiring Quetion)
« Reply #1 on: January 10, 2023, 11:14:22 AM »
I would recommend replacing the entire wiring harness if it's in your budget to do so as this is an area you really don't want to "cheap out" on.  Most of the Firebird restoration parts places carry about the same brand which can be pretty pricey.  On occasion, you might catch a promo code that will help with the cost.  Hope this helps and good luck with your build.
Steve
