Author Topic: Power steering return line question. Vendor suggested  (Read 528 times)
itllfly
« on: December 30, 2022, 03:02:57 PM »
78 trans am power steering return line leaking at steering box. All replacement s show one end threaded and the other open for hose clamp. If you have replaced yours where did you buy from.  Thank you
itllfly
Re: Power steering return line question. Vendor suggested
« Reply #1 on: December 30, 2022, 04:48:12 PM »
iIts leaking at the fitting. Is there an O ring on it that could be leaking and is that part available
langss
« Reply #2 on: December 30, 2022, 10:18:40 PM »
Try Rock Auto....Pretty Easy Parts Look Up.....
« Reply #3 on: December 31, 2022, 04:41:40 AM »
The pressure lines are fittings both ends, low pressure return lines are fitting one end only. Google just brought up hundreds of options. Just have to confirm your engine type and make sure it's the same hose. No o-rings on the fittings. They are contact sealing with the fittings. You could try backing it off slightly then tightening again a few times to see if you get it to reseal.
« Last Edit: December 31, 2022, 04:56:47 AM by Wallington »
itllfly
« Reply #4 on: December 31, 2022, 07:49:50 AM »
Thank you I will give it a try
