Author Topic: Power trunk opener switch and connector  (Read 1453 times)
TA301
« on: December 24, 2022, 03:05:01 PM »
The connector with the orange wire has a single inlet while the back of the switch has two prongs. What gives?
aussieta
Re: Power trunk opener switch and connector
« Reply #1 on: December 24, 2022, 05:45:22 PM »
one side goes to constant positive
other side goes to trunk solemoid
basic normally open switch
1978 Y84 W72 WS6
« Reply #2 on: December 24, 2022, 08:14:13 PM »
Are you talking about the button in the glovebox?
Trunk solenoid is grounded to body, live wire goes to button and continues to solenoid, only links when button pressed to pop it.
Firebird 1978 Accessories Wiring Power Trunk Release by Ben, on Flickr
« Last Edit: December 24, 2022, 08:16:54 PM by Wallington »
TA301
« Reply #3 on: December 25, 2022, 02:38:18 PM »
Yes, the yellow button switch in the glove box. When I connect the orange connector and press, trunk does not open regardless of which prong it is connected to. I was wondering why it has two prongs when the connector has only one.
« Reply #4 on: December 25, 2022, 03:30:42 PM »
You've lost me. The trunk pop switch has two terminals, one comes from the live power source, the other goes to the trunk solenoid. It doesn't matter which is which, it doesn't know the difference. It only activates and completes circuit to trunk when button pushed, and solenoid pops.
aussieta
« Reply #5 on: December 25, 2022, 05:39:44 PM »
i think op has only connected the orange wire
may not have the black wire or even have the solenoid
1978 Y84 W72 WS6
TA301
« Reply #6 on: December 25, 2022, 05:44:23 PM »
Evidently, the black connector from the trunk release solenoid is missing or I can't locate it on the harness. That explains why it does not work. I installed a new dash rebuilt by Just Dashes and have everything connected except the trunk release.
« Reply #7 on: December 25, 2022, 05:48:12 PM »
If it's not original then likely not added to the harness. Easy to run an extra wire back, even just to test. Common plug if you want that too.
I added a NOS one to mine, came with some parts but no harness. Easy to add. I see a guy on ebay was selling his own harnesses, essentially he was grabbing a roll of wire and adding a plug to each end and calling it done! Not sure if he had any sales.
It's also an option, not sure it was ever part of the harness. I'll add a relay to mine, allow keyless trunk option from key remote to pop. Leave the glove box button and key as a back up.
« Last Edit: December 26, 2022, 09:30:04 PM by Wallington »
TA301
« Reply #8 on: December 27, 2022, 11:54:30 AM »
Correct. Can't locate the black wire. I had the original dash rebuilt to new. I will check to see if the black wire is hiding somewhere in the vicinity of where it should be. The car has the remote trunk release as original equipment since new.
TA301
« Reply #9 on: December 27, 2022, 11:59:44 AM »
Car has the remote trunk release factory installed and worked before the restoration started. Yes, I saw that harness on ebay as well. I will look carefully to find the harness. At the very least, I will remove the door sill scuff plate on the passenger side to enable me to trace that black ground wire since it is located there.
TA301
« Reply #10 on: January 04, 2023, 05:38:50 PM »
Found the ground wire/connector. During the restoration process, somehow it had ended up ziptied to the harness at the driver's side! It was really hard to access it but I managed to free it and reroute it to the switch. It has a butt connector with a red wire that is branching out of it. That wire has been cut and existed when the aftermarket alarm system installed back in 1992 used it. Upon connection to the switch, the trunk does not open when the switch is pressed. I am going to remove the butt connector and splice the black wire and hope it works.
aussieta
« Reply #11 on: January 04, 2023, 07:08:53 PM »
the aftermarket alarm would have had a remote trunk release
1978 Y84 W72 WS6
« Reply #12 on: January 04, 2023, 07:50:12 PM »
Half the alarms in 1992 were based on a simple voltage drop, didn't even offer unlocking, just on and off prior to getting your key out.
aussieta
« Reply #13 on: January 04, 2023, 09:36:17 PM »
i have had alarms with remote door and trunk from early 1990
viper brands
1978 Y84 W72 WS6
« Reply #14 on: January 05, 2023, 02:58:35 AM »
And the other half didn't.
aussieta
« Reply #15 on: January 05, 2023, 04:09:33 AM »
wheres that like button
1978 Y84 W72 WS6
