Author Topic: 301 Distributor and Plug Wire Installation  (Read 5598 times)
Seven
« on: December 12, 2022, 11:27:53 AM »
What is the factory distributor orientation and spark plug wire routing for a 1979 Trans Am, 4 speed?
Any pictures would be appreciated.
LT4 Firehawk
1979 Y84 T-top Delete
1972 Esprit 455 HO
TA301
Re: 301 Distributor and Plug Wire Installation
« Reply #1 on: May 10, 2023, 10:08:01 AM »
If by "orientation" you mean the rotation of the rotor, then it is counterclockwise.
Seven
« Reply #2 on: May 15, 2023, 11:49:46 AM »
No, the location the factory used for the number one spark plug wire terminal on the distributor cap.
LT4 Firehawk
1972 Esprit 455 HO
« Reply #3 on: May 15, 2023, 03:36:15 PM »
I got this off of a Motor Auto repair manual.
IMG_1779 by Lawrence Alexander, on Flickr
This one is from a Chilton's manual, basically the same but from a different angle. I have several factory service manuals, but they aren't showing the plug wiring.
IMG_1781 by Lawrence Alexander, on Flickr
« Last Edit: May 15, 2023, 04:19:48 PM by 5th T/A »
