Author Topic: rear bearing races  (Read 833 times)
wtatoy
rear bearing races
« on: December 10, 2022, 12:35:35 PM »
anyone pull rear bearings and find a black 'color' on the axle tube where the bearing presses
had it on the outside of the bearing as well, came off the bearing with cleaner but not on the axle tube
just curious
thanks in advice
Mike
79T/Aman
Re: rear bearing races
« Reply #1 on: December 20, 2022, 05:40:59 AM »
there are no bearing races, the roller bearings ride on the axle shaft and the bearings are pressed in the housing not on the axle.
