Author Topic: New Cat gets beet red and car runs rough  (Read 1186 times)
inspector_mike
« on: December 07, 2022, 08:54:49 PM »
Hi all. hope someone can help me out there. I have installed new 2 1/2 inch exhaust from manifolds to end. installed 2 old cats, 2 new magna flow mufflers and x pipe configuration. passenger cat got beet red, car started to bog down. replaced new cats with 2 new magna flow high flow cats and magna flow mufflers. same thing happened
mechanic said that the old large pie shape CAT was a 3 or multi flow cat and the new cats are one way flow that do not work with the unburnt gas from the carb and that is the reason why the cat is getting red.
can someone help me
not sure why only one cat gets red only>
thanks Mike
Re: New Cat gets beet red and car runs rough
« Reply #1 on: December 08, 2022, 04:49:07 AM »
1980 301?
« Reply #2 on: December 08, 2022, 05:18:37 AM »
Could it be running rich and loading up cats with raw fuel.
inspector_mike
« Reply #3 on: December 13, 2022, 09:37:05 AM »
Thank you for the responses. adjusting the carb fuel for richness, replacing the plugs worked
Thanks again
Mike from Canada
