Author Topic: Madaguy 1955 Nomad Build  (Read 71618 times)
Re: Madaguy 1955 Nomad Build
« Reply #320 on: March 12, 2025, 06:40:31 AM »
20250228_145340 by Kerry Grubb, on Flickr
Springs came without a box, I bought 4 tires online for my truck. This is how they arrived. Fed Ex driver told me he had no idea where the 4th one was but that it should show up in a day or two :shock:
It came the next day.
« Reply #321 on: March 12, 2025, 02:12:05 PM »
I've had tires shipped to me like that too. I guess it's more efficient that way haha.
« Reply #322 on: March 19, 2025, 09:40:51 AM »
It's been a while since I've been back into the swing of things and got some work done to the car. I've been collecting parts, buying/selling, house projects and etc, but now I want to get back to the car and ready for some warm weather cruising. There are several things with the front end that I want to address, but first up was the stance. I installed the CPP C5 2" Drop springs and tubular control arms last fall, but after I got them installed it seemed to be no change in the stance. I think with the isolator cups in the bottom of the lower control arms it acted as a spring spacer to offset the gain from the 2" drop spindles. I opted to cut one coil off of the springs to hopefully stiffen the front end slightly and get a lower stance.
Initial measurement was 28" left and right.
Got it back together and the drop was about 1.5"
Before:
After:
It's hard to say how much it will change until I get it outside, but it is noticeably lower.
Next up was getting my original inner fenders installed. I didn't get any pictures, but I repaired the lip and some pin holes on the lower sections. Got them prepped and repainted with SEM Trim Black to match the firewall.
Started with some disassembly
Only a handful of hardware held on the front grill. We'll be changing that!
After struggling a bit to get it installed, I needed to remove the lower bolt down by the rocker to allow the fender to swing out. That gave me enough room to get the upper side into place. After wrestling with the fender a bit, I finally got a few screws in place. I also installed some original fender brackets I picked up that were powder coated and came with some original zinc coated hardware.
Took some time to clean up the core support and repaint, then installed some new aftermarket filler panels that I picked up several months ago. I painted them flat black, but it doesn't quite match the sheen of the Trim Black which I ran out of. I'll touch it up though before I button everything back up once I get a new can.
I notched the passenger's side where the transmission cooler lines go. Used a hole saw to get the radius and my tin snips to get the straight lines.
I ran out of the package of screws that I bought for this project so it's not final, but so far it looks way better than it did before. Inner fenders and new filler panels make a huge difference.
The I turned my attention to the front lower valance panel. I didn't pay much attention before, but the back is in pretty poor shape. I'm going to attempt to repair it, but may just pick up a new one when I'm at Spring Carlisle next month.
That's where I left the car a few days ago, but much more work will be done to clean up the engine bay. I was also able to snag some more key parts that will be very helpful with the next stage of my build. First up is a Mighty Mouse catch can. It's got the fittings for boost already installed, just need to buy or make a bracket for it to be installed.
Also my Quick Performance 9" housing and axles arrived! I haven't gotten a chance to take them out of the box, but they are really solid pieces and look very well built. 1/4" axle tubes, internal gussets, HD leaf pads, 35 spline axles and GM Flush mount ends. With those ends I'll be able to use my favorite rear disk brakes off of 98-02 Fbody's.
I still need to buy an assembled third member, new rear rotors, NiCopp line and other misc. things before I can assemble/paint the rear and get it installed. Then even before I could run the new rear, I'll need to get it installed and measure for a new heavy duty driveshaft. In the meantime, I plan to get the rear springs swapped out soon so that I can take the car to get a front end alignment and still keep the car functional. I also want to add my flex fuel sensor, swap to the Dorman LS2 intake, add the Vaporworx module and get it wired up. I haven't decided if I'll swap out my fuel pump now, or wait until the car is boosted to swap to the CTS-V pump.
Lots of moving parts, but I'll get them all figured out.
« Reply #323 on: March 19, 2025, 01:35:22 PM »
Lots of cool stuff going on. I really enjoy seeing what you are doing with this car.
« Reply #324 on: March 20, 2025, 02:52:52 AM »
Very exciting stuff!!!  What’s the Mighty Mouse Catch Can do?
« Reply #325 on: March 20, 2025, 05:59:03 AM »
I wondered the same thing.
« Reply #326 on: March 20, 2025, 09:27:36 AM »
Ryan: the car looks great. I always enjoy your updates.
Google is your friend.
https://www.mightymousesolutions.com/catch-cans
« Reply #327 on: March 20, 2025, 08:06:10 PM »
Thanks guys. The catch can is part of the pcv system and runs the crankcase air that normally travels to the intake, through the catch can instead. Inside the air travels through a wire mesh that allows the oil and dirty air to deposit contaminates and store them in the can rather than back into the intake. LS motors are pretty notorious for using oil and collecting in the intakes. If you see some posts from about 6 months ago, my intake was full of oil. I swapped to a valley cover with pcv like the LS3 motors have, but they will still pull oil even with that. Should help the motor run cleaner.
« Reply #328 on: March 21, 2025, 06:10:01 AM »
Thanks, that makes sense, it looks like these cans are even more important on a boosted motor
« Reply #329 on: March 31, 2025, 09:48:14 AM »
Another weekend and some more progress. I've been working a little bit at a time to get closer to installing the Dorman LS2 intake, and it got to the point where I was ready to pull my TBSS intake and do the first test fit. First up was to swap out the stock valley cover bolts for the low profile cap bolts to clear since the intake sits a little bit lower.
First test fit was happy at first because it looks way better than the truck intake, but soon was slightly disappointed because the water pump won't work with the throttlebody. I'm too far down the path now, so I have to move forward with my intake swap. I found a few good deal on eBay for a low mileage C6 water pump and balancer. More research was needed on what the best plan would be for the alternator bracket. I eventually wanted to swap to the Corvette accessories to gain 1.5" in front of the engine for turbo stuff, but this situation sort of forced my hand.
Since I need to swap the balancer and swap water pumps, it was much easier to just pull the radiator to get that out of the way. While I had that off, I might as well fix the driver's side frame horn! It was bent in and the top was twisted in as well. I could have used a porta-power I didn't feel like buying one for this project, so I used what I had. My press jack, my BFH, slide hammer, welder and leverage when I could.
Don't try this at home. It didn't work well at all and was quite sketchy.
Before:
After:
I wasn't striving for perfection, but rather a frame that measured straight and within specs for width. I tried to get it back as close as I reasonably could to the original look. I think it turned out pretty good considering the tools I had available.
Another little unexpected surprise was picking up a set of cool late 90's gauges from Custom Rod Gauges. The guy selling them said that all the gauges but the speedometer worked. I took a chance since he was selling them so cheap. The overall reviews for the company seem to be poor customer service, but a quality product. The gauges are all VDO internals.
After pulling off the back cover, I noticed that one of the leads had the solder broke off. I connected it to the right connection and the gauge fired right up! WIN. They came with all the sensors and just overall needs a little TLC. I haven't fully decided if I'm going to run them because I really do love the original gauges. But good to know that they all work.
I also found some electrical tape on the speed sensor wiring that came with it. Each lead was crudely wrapped with electrical tape. I wonder if that had any reason to do with why the Speedo wasn't working??
I placed my order for the Speedway 9" assembled third member with 3.25 gears and 35 spline Helical Posi unit. While I was on there, I also saw something pop up for a sway bar in the garage sale section. Comments said it appeared to be installed, but returned for one reason or another. It had a decent discount so I grabbed it too. The hardware was brand new so it had never been installed, but I think some paint was scuffed off in shipment. That's fine with me. Easy touch up. That's another reason why I needed to straighten out the frame because where the sway bar mounts to the frame didn't sit flat.
I ordered a bunch of parts to finish the install for my 9", catch can, fuel pump controller and other misc. things. Once it all gets here, I'll be able to button everything up fairly quickly and get some more road miles on the car this season. The weather rapidly changed and we're in full on spring here in central Virginia. Can't wait to get it back on the road!
« Reply #330 on: April 02, 2025, 05:56:05 AM »
Good update :grin:
« Reply #331 on: April 02, 2025, 08:08:08 AM »
That frame straightening scared me but good job!
« Reply #332 on: April 03, 2025, 06:57:33 AM »
Made quite a bit of progress over the last several days. With the frame horn fixed, I was able to get the sway bar installed. The bushings sat nice and flat on the bottom of the frame rails, so that made me happy.
My C6 balancer came in. Was a new takeoff piece from a crate motor. I have the puller, flywheel locking tool and installation tools already so this was a pretty quick swap. Pull the truck balancer and install the C6 unit.
After researching a bunch of different options for the alternator/PS brackets, I decided on the unit made by Holley that replicates the stock C6 bracket. The big difference is the alternator spacing, which allows you to use the more common truck units. Since I already had a good alternator, it made sense to pay a little more for this one so I didn't also need to buy a new alternator. And it will likely be easier/cheaper to replace if this one fails at some point. I ordered it through Summit, and while I placed the order I also grabbed the rest of the fittings to install my Mighty Mouse catch can.
The Holley bracket is a really nicely cast piece. It's incredibly smooth out of the box and looks to be very well made.
I had a mix match of parts, and decided to paint all of the brackets and accessories satan black. I've seen a lot of motors with that combo and I wanted to clean up the looks of the engine bay while I'm in this deep.
For some reason they were still tacky the next day so I set them out in the sun for about 4 hours to cure.
Once they were all painted up, it was finally time to see how they looked on my motor with the new intake. Very pleased with how they turned out. I've always liked the way the alternators looked painted all black.
Then another issue popped up. I went to test fit a belt I have and quickly realized that the tensioner is very close to the throttlebody plug. After researching many different options, I realized that it must be because this intake was designed to work with LS1 accessories. I tried flipping the TB, but the motor hits the water pump.
After a few degrees of rotation it contacted the connector, so that will not work.
After thinking on it a while, I got the idea to try and rotate the tensioner on the lower mount. BINGO!
It rotated it enough to allow for full articulation of the tensioner. I cut the boss off of an old truck tensioner that I had laying around and will weld it to the original tensioner so that it won't move around. The good news is the tensioner is pulling towards the stud rather than away from it, so there will always be a force in the right direction.
I used an old truck water pump I had to bolt it all in place so that I could TIG weld it into place. I'm a beginner, but the weld will definitely hold it in place. Then I milled the reverse side flat so allow the bolt head to sit flush.
Touched up the paint, and I think it looks great!
Before the final installation of the accessories, I drilled and tapped the water pump for the steam port lines. When I first put the engine together I realized that I had some block off plates in the front, so it wasn't ever fully bleeding the air from the system. This will be a good piece of mind update.
In order to install the LS3 style 1000cc injectors into this intake, I had to make some new brackets for the fuel rails I bought. They are generic Amazon rails, but do look to be well built. I used some aluminum angle bulk from Lowe's and it ended up being the perfect height for these injectors. Just trimmed them down and rounded off the edges. Then painted.
Once the brackets dried, I installed them onto the fuel rails and installed on the car. I'm really happy with how this update turned out. I figured while I'm swapping intakes I might as well get the new injectors installed so that I'll be that much closer when I add the turbo. It will take a bit of time to get my new base VE table updated, but I think the existing table will give me a great base to start from.
I also received my 9" third member from Speedway a few days ago. It was packaged up really well, and I only pulled the cover off to take a picture but for now it's staying in the case for safe keeping. It's a Nodular Iron third member with 35 spline Helical Posi differential and 3.25 gears. I'm really excited about putting together the rear end, but for now I want to focus on getting the engine bay back together. I have a complete LS1 rear disk brake setup for it as well. Just needs to be cleaned up and painted since the backing plates need to be installed before the bearings can be installed. I opted for the GM bolt pattern flush mount ends which are designed to work with these brakes.
Over the next week or so I'm hoping to get the flex fuel sensor mounted and installed, reinstall the battery and re-route some cables, loom all the wires in the engine bay, install the fuel pump controller (requires installing 8 ga wire to the rear of the car and tapping into the MAP sensor), and modifying the CTS-V fuel pump assembly so that I can swap that into my tank. I was going to just run the car as is, but if I do that, I'll end up needing to modify my VE table twice. With the fuel pump controller it will ramp up based on boost pressure and because of this, I like to run the pumps at a starting pressure of 43psi. Going from a base pressure of 58psi to 43psi will change the fueling required in my VE Table.
« Reply #333 on: April 03, 2025, 12:28:37 PM »
Ryan, every time I read your updates all I can think about is how many balls you have in the air at one time and how far this car has come. I will be curious to hear your critique on how the car handles after the suspension upgrades. That new pumpkin is almost too pretty to be hidden under your car! Once you do the power upgrades you’ll be glad to have such a stout transmission and differential. This thing will be a monster when finished and still have great street manners for cruising with a reliable EFI LS.
I am out of town visiting friends, kind of a crummy weather day, so I had a chance to reread all your posts from the beginning. Amazing!
