So, I have continued to work on this off and on. I have finished rebuilding the rear leaf springs but I switched out the overload spring (because one was cracked in half) with a flattened helper leafs I had laying around.
I pulled them apart and wire wheeled each leaf and sprayed them each with epoxy. I then cut strips of UHMW (ultra high molecular weight)polyethylene 1/8 thick to put between the leafs. I used this when I built the springs for my solid alxe swapped S10 Blazer. It is super durable and slippery so the springs actually slide. Anyway both sets are done and assembled. I'll get some finished pictures soon.
Logan helped and spray some leafs amd other miscellaneous parts in epoxy.
Once we got the springs rebuilt with new eye bushings, pins and clamps we started to wire wheel and use a acid solution to clean and strip the gm 8.6 differential.
Now this part you guys might find useful/beneficial. I am rebuilding the S10 rear disk brakes which is a swap many do to our Firebirds.
I pulled the rear cover and removed the screw pin that holds the spider gears in place. This let's you push the axles in just enough so you van remove the retaining C clip. Once the clip is out you can pull the axle shaft.
You need to remove your original backing plate to install the S10 one like this. I media blasted this, sprayed it with epoxy and then VHT satin roll bar paint.
I then installed this emergency brake rebuild kit. The only part you need to keep is the little lever that the cable attaches to.
Here you can see the slightly rusted lever. I lubed up yhe internals with high temp brake grease too.
A separate kit has the adjuster wheels. Which I installed along with the brake shoe retaining clip (ar the top)
I then installed a new backing plate and the parking brake shoe. Th backing plate was completely rusted and gone from all 3 of the S10 axles I have so new ones were sourced. It was kink of hard to find these so I don't know how much longer they'll be around.
While you are at it you should replace the axle seals and clean up the axle shaft too.
I have all of the part numbers somewhere that I used and I can list them if others will find it helpful. Also once I get the diffential completely assembled, I'll show how (or not) the 8" trans am snowflake rim fits.
More to come hopefully soon!
