Author Topic: Bulkhead Connector Question  (Read 971 times)
Brandon_78TransAm
« on: November 11, 2022, 02:01:40 PM »
I have a 78 w/ Pontiac 400 and I have determined my engine harness is toast, there's been too many bodged and burnt wires. So I have decided I am going to rebuild the harness with new wire and connectors. My question is, what is all the nasty thick brown grease that is packed in it inside and out? I've read its anywhere from Dielectric grease to axle grease. I'd like to seal it back with whatever it was by stock and if that's not available what else could be used to seal it from the weather? Thank you
1978 Trans Am
Re: Bulkhead Connector Question
« Reply #1 on: November 11, 2022, 02:24:37 PM »
I would use dielectric grease.
« Reply #2 on: November 11, 2022, 08:18:09 PM »
It's a gunky sealant. No point spraying degreaser about only to remove it all and let the water in.
NY81TTASE
  • '81 turbo trans am SE
« Reply #3 on: November 12, 2022, 04:14:31 PM »
We use this at work. We call it elephant doo doo^. This is gray but I'm not sure if it comes black, if color matters to you
Or you can search buryl sealants
Ideal Industries 31-601 Duct Seal 1 lb Dark Putty Gray https://a.co/d/aNuFG7e
« Last Edit: November 12, 2022, 04:16:14 PM by NY81TTASE »
1981 turbo trans am se
