Author Topic: Looking for 350 2bl Vacuum Diagram  (Read 922 times)
L8KRFAN
« on: October 22, 2022, 12:26:14 PM »
Anyone happen to have a vacuum hose diagram for 1974 Esprit with 350 2bl carb? It's a ZA California car if that makes any difference. Google search found plenty of 400 4bl but nothing to help me out. Thanks in advance!  :D
Los Angeles, California
1974 Firebird Esprit 350
Re: Looking for 350 2bl Vacuum Diagram
« Reply #1 on: October 22, 2022, 07:58:14 PM »
Just scanning a few pages now. Does it/did it have the smog pump too?
In case you see similar diagrams, other 1974 350 2-bbl w/auto setups were YA-YB-YC, AA, ZA-ZB. Different cam on the ZA_ZB for California.
Not sure if these help.
2022-10-23 (2) by Ben, on Flickr
« Last Edit: October 22, 2022, 08:07:56 PM by Wallington »
L8KRFAN
« Reply #2 on: October 23, 2022, 12:24:20 PM »
Thank you thank you thank you! This is a great start. Mine is indeed a ZA California low compression 350.
Yes mine has the smog pump but no belt so I may remove it.
Much a appreciated.  :-D
« Last Edit: October 23, 2022, 12:26:52 PM by L8KRFAN »
« Reply #3 on: October 23, 2022, 06:29:23 PM »
I also have the standard 350 2bbl diagram for if you have most removed or disconnected, but it isn't a lot less.
L8KRFAN
« Reply #4 on: October 23, 2022, 07:42:40 PM »
The top image helped me a lot! It validated what I have is mostly correct. The only difference is that the previous owner is getting vacuum to the distributer advance from the carb rather than from the thermal vacuum valve on the manifold as shown in the diagram but not sure if that's really a big deal. Also, one of the ports on that same valve that used to go to the air pump is blocked off so that's good since its doesn't even have a belt.
Thanks again!
« Reply #5 on: October 24, 2022, 12:42:46 AM »
A lot of the thermal vacuum switches and valves are no longer available or where once were specific, now covered by several broader settings. That may or may not affect original look or function, especially for those in CA.
