Author Topic: Time to really upgrade my clutch  (Read 556 times)
H8Rain
« on: September 19, 2022, 12:50:39 PM »
When I purchased my car 10 years ago the original owner had upgraded the engine, trans and rear end.  It dynos around the 500 HP/TQ range.  When I purchased the car it had a SPEC clutch set up in it.  I hated the way it drove so I swapped that out for a Centerforce high-performance single disc clutch, pressure plate, flywheel and throwout bearing.  That ran me about $850 for the parts (I installed it).
That was 10 years ago... fast forward to today and I have put a whopping 7k miles on that clutch.  I usually drive very conservatively but do like to get on it from time to time.  This past weekend the clutch started to slip.
Now that I need to replace it again, I did some new research and it looks like I really should be running a multi-disc set up for the power I am putting out.  Centerforce does have (1) option for a 77 TA.
I'm just curious what peoples thoughts are on the single vs mult disc and if any of you have any other brands you would recommend looking at that would be good for 500+ HP/TQ.   Not looking for a racing clutch.  Something with a nice smooth engagement.
Thanks!
Mark
Manual
95K Miles (1k on engine , trans, diff)
H8Rain
Re: Time to really upgrade my clutch
« Reply #1 on: September 19, 2022, 01:38:25 PM »
This is the one that I have been running with for the past 7k miles.  I was surprised when I went online to look it up again and it is rated for 622 ft/tq.
Mark
Manual
Vroom_vroom
  • ka-kawwww
    • my build thread
« Reply #2 on: September 22, 2022, 05:14:47 AM »
mcleod has 3 they offer for twin discs. the entry one is rated for 800 but says not for competition use. there rxt says it will take it and still be a smooth engagement supporting 1000. not making anywhere close to that but im swapping in drag radials so im thinking of making the switch as well.
'19 Silverado 3500
'15 terrain
« Reply #3 on: September 22, 2022, 06:20:01 AM »
I went from the LS7 Clutch and 7/8" bore when I had my LS1 engine. It sounds very similar to the specs on your current clutch. I didn't like that it was so stiff, but I lived with it. Then when I was building my LS3 with LSA supercharger, I needed something that would hold around 800 flywheel HP. I picked up an RXT clutch from McLeod, and I loved it. I also swapped out to a 3/4" bore MC and with that combo, it was just slightly more stiff than what you'd expect from a stock clutch, but would grab like no tomorrow. I would highly recommend that clutch, and possibly going with a hydraulic setup. I would probably go with the RST clutch since the RXT is rated for 1200 HP.
« Reply #4 on: September 22, 2022, 07:51:20 AM »
The McLeod standard clutch I had in the LeMans worked very well.
