Author Topic: Does this look right?  (Read 1454 times)
NY81TTASE
  • '81 turbo trans am SE
« on: September 18, 2022, 01:08:15 PM »
It doesn't to me. Looks like too much of the tabs are showing.   Should the headlight plug be closer to the bulb? Mine won't push on that far.
1981 turbo trans am se
Re: Does this look right?
« Reply #1 on: September 18, 2022, 02:40:05 PM »
How long are the tabs?
« Reply #2 on: September 18, 2022, 02:40:20 PM »
Yea I want to say mine are further on. I can check and send a pic in a bit
NY81TTASE
« Reply #3 on: September 18, 2022, 04:12:51 PM »
Maybe more than an inch?  They won't go further because of those little tabs sticking out halfway down. If those tabs were missing, im not sure how far down the connector would even go
« Reply #4 on: September 19, 2022, 06:32:51 AM »
That looks normal to me given they are pushed on up to those tabs. That's what they are there for, to positively stop the tabs from going further into the terminal and possibly causing damage.  :cool:
NY81TTASE
« Reply #5 on: September 19, 2022, 09:28:20 AM »
I was expecting the connector to click on to a tab to lock it on more securely. The connector comes off very easily.
« Reply #6 on: September 19, 2022, 09:56:30 AM »
The terminals on the plug side are probably worn. I'd try and get a pick in there and try to bend the terminals up slightly to give it more tension when plugged in. You can also de-pin the wire terminal from the plug by depressing the tang that holds it into the connector. It should slide out and you can have full access to it.
NY81TTASE
« Reply #7 on: September 19, 2022, 12:23:43 PM »
Thanks,,I will do that. They also need to be cleaned of oxidation
arocars
« Reply #8 on: October 25, 2022, 06:09:36 AM »
That does not look right to me. The plug is not on far enough, that's why it slides right off again. Does the other side look like that too? Take it apart to get a better grip on it and try again. There should be about three eighths inches between the back of the light and the front of the plug.
« Reply #9 on: October 25, 2022, 10:59:03 AM »
Looks like someone J/B welded those tabs on there.  Are those the OEM tabs?
« Reply #10 on: October 26, 2022, 09:43:46 AM »
It looks 100% right to me.
they don't lock on.
« Reply #11 on: October 26, 2022, 01:37:34 PM »
I don't think it's 100% right otherwise NY81TTASE would not have started this thread.  Too much of the tab is showing.  Easy to short out and blow a fuse.
This is off a Sylvania H4656
« Last Edit: October 26, 2022, 01:42:01 PM by 81Blackbird »
« Reply #12 on: October 26, 2022, 02:46:29 PM »
I agree, way too long of tabs.
NY81TTASE
« Reply #13 on: November 09, 2022, 11:57:03 AM »
Sorry to be so late getting back...
All 4 lights are brand new from rockauto and all 4 fit the same way.  End result...I think there is nothing I can do about it except hope they don't vibrate off.
« Reply #14 on: November 09, 2022, 07:09:00 PM »
Look like they are likely designed to fit a few similar but still different applications/plugs.
« Reply #15 on: November 11, 2022, 02:27:53 PM »
If I remember correctly there is a secondary cap attached to the plug.
NY81TTASE
« Reply #16 on: November 11, 2022, 03:34:33 PM »
I'm interested to see what that would look like
