Author Topic: Kick panel fitment  (Read 1018 times)
NY81TTASE
  • '81 turbo trans am SE
Kick panel fitment
« on: August 29, 2022, 09:33:55 AM »
Years ago I removed the passenger side kick panel and I  just decided to replace it because I have too many parts scattered about.
  I noticed that there are screws that possibly hold the round cover to the kick panel. One of these front most screws is lined up directly with the harness that goes to the door. It looks like the screw will rub on the wires and eventually cause an issue.
Does something seem wrong? Is the harness in the wrong spot? I never played with interior trim.
I can try to get pics.
81 turbo ta
1981 turbo trans am se
NY81TTASE
Re: Kick panel fitment
« Reply #1 on: September 04, 2022, 08:04:15 AM »
Can anyone verify how the harness is run??
« Reply #2 on: September 04, 2022, 01:20:23 PM »
From my Y88.....hope this helps
NY81TTASE
« Reply #3 on: September 04, 2022, 05:57:49 PM »
It sort of does help. Thank you. I see your harness is running different than mine. I couldn't get a good pic but mine comes from the jamb hole and goes straight up, behind the screw . I have no clue how to move it.
