It's a Sat., and I've needed to fell a tree in my backyard, (for over a yr), and am just getting around to it. But all wasn't perfect, I wasn't confident, got distracted, and then...the uni-bell showed up, so the tree can wait. Decided to show you guys some pics, before I continue.
The photo above shows the basic uni-bell, but I wanted to show the differences between "it", and a regular BOP bell. Wanted to know where not only the fork pivot ball location is, but the hole for the fork lever to protrude. Hopefully these will help some-one.
And the fork above is from a 3rd gen, (chevy), and can you see the bend in the lever? I don't have a second gen one at this time to lay out, but it doesn't hardly bend at all. That bend would help clear the floor pan in the 3rd gen, if you ended up using the original BOP bell, and not relocate the fork piot. Not sure what it'll look like, till I get all in place.
One "potential" problem I see is the relief casting for the nose housings of the starter. The "bulges" in the uni-bell, are a bit smaller, (about 1/2 the size) than the original. I hope it doesn't lead to a starter issue. Worst case scenario, I'll need-ta open them up. They're just covers for the starter anyway.
In the clutch linkage photos below, you'll notice the Z bar in place. I need one missing bracket that attaches to the frame side, so currently it's just laid in place. The "S" shape of the tube is needed to clear the floor pan, unlike the 2nd gens, (and everything else for the past 50 yrs). To this day, I don't understand those designers reasoning. It's got to do with the eng. set so far back, into the tunnel.
Also, amazingly, the link going to the pedal, has a bend in it, and it actually fits into the thru hole I cut for the hyd. master cylinder. I'm happy about that, but can see how the design is inferior, due to all those bends, and the unwanted stress in operation. Fortunately the travel is minimal.
And to conclude this lengthy post, pics below are for you to see the clearance issue to the floor, with the clutch fork lever location, in the BOP bell. Very close. With the new bell, it'll be 1" lower, and will not only clear that, but maintain the correct factory geometry. If you look hard enuff you'll see the lower lever is a bit "beat-up", and will need some attention.
And that's all for now folks. Was wondering about the placement of the photos side by side, or stacked. Any preferences?
Hmmm. Looks like they'll be stacked anyway.
