Author Topic: Saginaw 3 speed to Super T-10 transmission swap  (Read 459 times)
Seven
« on: July 25, 2022, 11:56:06 AM »
I'm planning to swap a 4 speed into my 1972 Firebird.  Will a saginaw manual 3 speed bell housing work with a Borg Warner Super T-10?
Will I need a different transmission yoke?
LT4 Firehawk
1979 Y84 T-top Delete
1972 Esprit 455 HO
Re: Saginaw 3 speed to Super T-10 transmission swap
« Reply #1 on: July 26, 2022, 06:30:46 AM »
Can't speak on the bellhousing, but I'm certain you'll need a new yoke. The super t-10 trans uses a 31 spline big yoke.
« Reply #2 on: July 26, 2022, 09:13:41 AM »
Bellhousing will fit.  I admit I haven't done it.
« Reply #3 on: July 26, 2022, 05:06:02 PM »
I had a 72 GTO, M-20 Muncie and it had the big TH400 yoke. I didn't know you got a Saginaw 3 spd, in the Firebird in 72, but I guess it probably would have a small output shaft. As for the bellhousing, like Joe said, I would "think" it would be the same. But with general motors, you never know what you get. I'm sure the bolt patterns for the block, and tranny are the same. And of course, the depth for the input shaft should be the same too. And lastly, I would "expect", the pilot hole diameter for the frt brg retainer to be the same. But never had one to compare. Good luck with the swap. It'll be worth it.
