Hello everyone, looking for some help with an engine vibration between 2300 - 2600 RPM. The vibration is present in neutral and park. It is high amplitude at crankshaft speed. I tried unbolting the convertor and running the engine, the vibration is gone. If I bolt it back, you guessed it, harsh vibration. The torque convertor is a Jegs model 2200 stall and it did not look like it needed shims. Fell right on the specs. I tried phasing it with no luck but it does seem to change. The transmission is a TH350 that was completely rebuilt with clutches and seal. There is also a new damper and flex plate. All the diagnostics are pointing to the convertor which I replaced twice with the same brand. Any help is always appreciated. Thank you in advance.
