I wanted touch up some spots and use normal enamel but I thought it might peel if it was over lacquer. I'm pretty sure my 81 exterior is lacquer, I think it says it in the cowl tag(?), but I put lacquer on a rag and tried to "clean" a spot. Bad move. The paint came off , not all the way but definitely a layer.
I guess I will use the semi flat or semi gloss enamel just to protect what I clean up. I'm not looking at a restoration just a good fix.
