Author Topic: Trunk brace hole?  (Read 967 times)
Trunk brace hole?
« on: May 13, 2022, 03:57:33 AM »
I noticed the LH trunk brace stiffener on some cars has this slot and hole, others don't. In a quick look of my saved pics that don't have a mat in the way, some 77 do, some 77 don't, and all my 78-81 that show it do.
It looks like where you would insert a U-nut retainer, push it across, then use the screw hole....but what was it's purpose, if any was ever realised?!
1978 TA low mileage original trunk spatter paint 3 brake lights bumper bolts by Aus78Formula, on Flickr
Firebird trunk brace hole by Aus78Formula, on Flickr
Re: Trunk brace hole?
« Reply #1 on: May 13, 2022, 04:26:10 AM »
Interesting.  I'm curious as well. Maybe a planed spot change from he air cylinder for the spare or something??
« Reply #2 on: May 13, 2022, 06:16:35 AM »
I had to rebuild that piece on my 77 but dont recall the hole being there. Will have to look at my 79. Def looks like a spot for a clip and screw.
sreta
« Reply #3 on: May 14, 2022, 07:26:01 AM »
It's for the taillight wiring harness ground clip
« Reply #4 on: May 14, 2022, 08:35:07 AM »
Interesting..what model is that? Mine doesn't have one like that and mounts to the trunk latch housing.
sreta
« Reply #5 on: May 14, 2022, 04:12:34 PM »
Mine is '79 TA
« Reply #6 on: May 14, 2022, 07:03:07 PM »
Well there you go. Must have been setting up for the new model a year early. I'm not terribly familiar with the 79-81 details and don't recall seeing that grounding clip before. Pic saved. Thanks!
Maxthe222
« Reply #7 on: May 15, 2022, 03:21:54 AM »
Both my '79's had a ground in that little hole, one had rusted away so badly it was fused together, when replaced with an aftermarket panel, that hole is no longer present, I may cut one out for that ground
1987 T/A GTA L98
1979 T/A Y84 WS6
1979 F/A W72 WS6
1978 T/A L80 WS6
1978 Formula L80 W50
1971 Formula 400 4-Speed
