Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
TAC Tech
Mechanical
Problem pypes exhaust system vs brake hose
« previous
next »
Pages: [
1
Author
Topic: Problem pypes exhaust system vs brake hose (Read 1027 times)
maltoch
79 formula - 301 - totally restored
on:
April 26, 2022, 12:25:51 PM »
Hi from France
Pypes 1 rear muffler.
I have a problem with my pypes exhaust system and m'y rear brake hose on the rear axle.
I tried many positions and the hose is against the exhaust ans burns or the angle is Bad.
Has someone a solution ? longer hose home made ?
I tried to move it a little bit left ...reverse its position...
If someone has a solution and.pics
I AM FRENCH AND LIVE IN FRANCE
job :champagne
food : snails, frogs and fromage.
hobbies : 79 formula
maltoch
Re: Problem pypes exhaust system vs brake hose
Reply #1 on:
April 26, 2022, 12:56:39 PM »
Thank you for the help but i talked about the centre brake hose...thé flexible....on the rear axle
Last Edit: April 26, 2022, 01:36:54 PM by maltoch
job :champagne
maltoch
Reply #2 on:
April 28, 2022, 10:35:22 AM »
Exactly what i did on first Time in the first pic...but it touches thé exhaust and i used aplastic band to put thé hose away
...but technical control in France pas bot happy with that.
On 2nd pic it should.be ok...but thé hose i surely.longer than stock....home made one...where to find the cubewith thé three connections...or a shop that Can do that...
job :champagne
maltoch
Reply #3 on:
April 28, 2022, 10:44:30 PM »
I talked about your pics. I didn't post anyone.
job :champagne
maltoch
Reply #4 on:
April 29, 2022, 02:46:33 AM »
I will take pics ..not soon...i m not at home.
job :champagne
Reply #4 on:
Fbird
Reply #5 on:
May 01, 2022, 01:27:18 PM »
25 yrs ago when I ran 3" tubes all the way out, I simple cut the braket off of the rearend and rotated it about 30 degrees and rewelded. So instead of it being on the "front side" of axle tube...its kinda on the rear facing side of tube.
67 Firebird
1981 Turbo TA (injected 400 now
maltoch
Reply #6 on:
May 02, 2022, 08:00:10 AM »
Thank you for tour help.
Not a Bad idea.
job :champagne
SoupMan
Reply #7 on:
May 05, 2022, 02:59:57 PM »
Maltoch,
Had the same problem. Did this which is exactly what a previous user posted.
Found out mine is sitting too close again since I lowered the car so I'll have to address that.
sreta
Reply #8 on:
May 05, 2022, 03:29:04 PM »
My rear end doesn't have that bracket, only small metal tabs which hold solid brake lines to the tubes. Brass T block is bolted with one of the differential cover bolts.
Reply #8 on:
Pages: [
1
« previous
next »
TAC Tech
Mechanical
