Pulling the motor out of my 1977 trans am for various small fixes. While it’s out I’m gonna pull the front subframe and replace body mounts, control arm bushings, and sway bar bushings with new polyurethane. I’ve read on other forums that poly bushing in control arms on 1st and 2nd gen cars can cause the control arms to not flex right since they are designed for rubber. I also have concerns about squeaking when new or old. I’m not terribly concerned with ride quality, although if that’s going to be effected much Id like to know. I just want them to last, not throw anything off, or squeak to high heaven.
I’ve already removed the rear axle and replaced all the rear bushings with rubber. 6 moths of sitting and driving around the neighborhood they are squeaking and the inner sleeves have eaten the rubber inside the bushings. I’ll go back redo those with poly bushings if they are a good idea.
