Author Topic: power steering pump question  (Read 1087 times)
prostreet64
« on: February 05, 2022, 03:28:01 PM »
I have a rebuilt power steering pump for my 79 TransAm that I just installed. The front bracket uses 2 of the 4 threaded holes to mount to the pump body. I thought the other 2 holes were just for different configurations but the lowest hole started leaking and then the fluid came out like an oil pan drain!  Do these pumps have a drain plug hole or is something way wrong?
1979 T/A with Olds 403, 4A heads (owner ported), RPM intake, Q-jet (by Cliff R.), th350, 3.73 posi. Mostly original with full interior and stock suspension, 3650 lbs. race weight. Best 1/4 mile 12.01 @ 111.14
Re: power steering pump question
« Reply #1 on: February 05, 2022, 09:29:36 PM »
« Last Edit: February 05, 2022, 10:10:23 PM by Wallington »
prostreet64
« Reply #2 on: February 06, 2022, 08:20:01 AM »
Yea, in your first pic it is the lower hole on the left side. I know they are supposed to be blind holes but that one is leaking like a drain. I am going to try a bolt with the flange type head and a washer like used on an oil pan bolt; this should seal it up, I hope.
